Carrera 3.2 Fog Lamp Issue
One of my fog lamps went out on my Carrera 3.2. I replaced the bulb but still no go. It's the stock H3, 55W. Thoughts?
2018 Porsche 911 GT3 manual
1984 Porsche 911 Carrera Targa
2021 Porsche Macan GTS
2018 BMW R1200GS Adventure Rallye
2020 Ducati Scrambler 1100 Sport Pro
Old 11-07-2023, 12:01 PM
Very easy to check for power and ground with a test light
Old 11-07-2023, 05:16 PM
Sorry, should have mentioned no power at the bulb.
Old 11-08-2023, 06:13 AM
Left side on - Right Off?
Check the connections from one lamp to the other side (jumper) as mine runs along front inside the trunk. Might have snagged it removing jack, etc, might have been disconnected due to other repair issue, or just corroded.
Old 11-08-2023, 09:23 AM
Yes, I’ll check this, thanks!
Old 11-09-2023, 06:10 PM
If you replaced the bulb and it's still not working, there could be a few possibilities. It could be a problem with the wiring, a blown fuse, or even a faulty switch. It might be worth checking those areas next.
Old 11-11-2023, 03:36 AM
You nailed it! One of the spade connectors wasn't completely plugged in, and it blew the fuse. New fuse, cleaned the connectors and seated them tightly, and fog lights! I recently had the fuel tank pulled out and refinished, so it must have been disconnected then. Thanks a lot!
Old 11-14-2023, 01:24 PM
