POVI's Avatar
HELP ! ...question on 3.6 liter plugs and ignition
Hi everyone ..
have a couple of questions on a 1990 3.6 liter motor ..
what spark plug numbers and gap specs ?
also can you unplug either one of the harness's from the 2 ignition modules , and keep the motor running ?
I unplug one side , and the motor still runs , then i put that one back on and then i unplug the other one and the motor dies ??? .. i thought that they were 2 seperate systems ??
Please advise .. thanks in advance !
Joe
Old 06-17-2003, 06:54 PM
Irrationally exuberant
ChrisBennet's Avatar
It sounds like your distributor belt is broken. I wouldn't advise doing it again but when you disconnected the distributor, did it die when you disconnected the distributor closest to the fan? The 2nd distributor (furthest from the fan) is driven by a belt off the 1st distributor.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-17-2003, 07:28 PM
POVI's Avatar
Good tip Chris,
I forgot which one dies , but i think its the one fartest from the fan that kills the engine .. I'll swap distributor main hi-volt leads from the known good one to the other dist and see what happens, and pull the cap and see if belt is intact..car does have belt vent kit in it ..but who knows
The symptoms are ...
Car was running great up to yesturday , now the car runs and starts fine , but only under HEAVY acceleration i get a strong miss , sort of like a fuel pump cut off on a 930 turbo , if i let off the gas and just cruise or acelerate lightly to moderatly , it runs great ?????
any body else have a input to possible solution ???
Thanks Chris , and everyone !
- Joe -
Old 06-17-2003, 07:36 PM
Administrator
Jack Olsen's Avatar
It's dangerous to run it at all with a broken belt, depending on what position it's resting in.
Old 06-17-2003, 07:38 PM
Sure sounds like a broken belt. Dick at Precision Imports can replace the belt. Not that you couldn't do it yourself but he has the experience and the belts on hand...
(Precision has moved, they are behind UHaul now.)
-Chris
Old 06-17-2003, 07:41 PM
POVI's Avatar
Chris, where abouts is presion imports .. are we talking Manchester on s. Willow st ? .. or Plastow on RT-125 ..
Also do you or anyone know what spark plugs are correct for the 3.6 i want to run out and pick up a set today ..also what gap
Thanks - Joe -
Old 06-18-2003, 03:51 AM
POVI's Avatar
update .. yes we have a broken belt !
Hi Chris , and everyone ..
OK i pulled the cap and rotor off the secondary distributor .. and YES .. i have a broken drive belt ... Im happy at least its a simple fix !
Is there any procedure on the web anywhere , for a step by step
replacing the belt correctly, and aligning the two rotors ?
Let me know ..thanks Joe
Old 06-18-2003, 04:52 AM
91C2wrencher's Avatar
POVI, you can check www.p-car.com and look in the DIY section for some giudence. As a note: When mine broke I found that the slave rotor shaft had a bad bearing(very notchy and hard to rotate). I had Steve Wiener(Rennsport.com) rebiuld mine for @ $150US. He did a very nice job including replacing the bad bearing, drilling the vent holes and new belt. I just pulled the dizzy myself and sent it to him, it was back in less than a week as I recall
1991 964 C2 -SOLD - miss it everyday -
2009 Honda CRV
2007 Audi A4 Quattro - just a sweet personal car -
2000 Land Rover Disco II - lifted
2001 GMC Seirra 1500HD CREWCAB
Old 06-18-2003, 06:06 AM
The PET shows an "FR6LDC" plug being used. Have fun getting to the lower ones. Precision is behind UHaul on South Willow. PM me if you need to borrow a distributor.
-Chris
Old 06-18-2003, 06:08 AM
My reference shows Bosch FR5DTC with a gap of 0.7 mm or 0.028 inches. Just how does one gap a multi-electrode plug anyway? I've (probably wrongly) just assumed they were gaped right of the box?
2009 Honda CRV
Old 06-18-2003, 06:17 AM
POVI's Avatar
Update ...
OK , i totally disassembled the distributor, and found that the clip that holds the distributor electrical connector on to the distributor housing .. somehow got loose and must have been bouncing around inside the distributor housing for some time, untill it came between the belt and one of the gears ....and thats what broke the distributor belt !
So I should have the dist. back together tommorrow and back on the road again !
Thanks again everyone
- Joe -
Old 06-18-2003, 06:03 PM
Where did you get another belt?
-Chris
Old 06-18-2003, 06:08 PM
POVI's Avatar
didnt get one yet ..be in tommorrow .. Ordered red label, and some other parts i needed at the same time.. you will have to come by sometime Chris, your not that far away !
Old 06-18-2003, 06:11 PM
