Moses's Avatar
Varioram update... No signal from DME
Well, I now have 2 DME's. One from a non V-ram '95 and a second from a '97 Vram. Using a voltmeter with long leads and driving with the motor under load, there is no signal from either DME to the V-ram.
I'm guessing my brilliant ex-mechanic wired this wrong. Anyone have any idea how the V-ram is supposed to be hooked up to the harness?
Old 06-16-2003, 08:25 AM
Have you checked that the DME is turning on pin n? Do you have a pinout diagram for your DME?
Here's the pinout for mine. There's a bunch of 'not used' pins, so those are either top-secret MS-like function calls, or one or more of them would run the V-Ram.
Old 06-16-2003, 08:33 AM
Moses's Avatar
Thanks Thom,
I'll look for a pin-out diagram. Any idea where to look?
Old 06-16-2003, 08:38 AM
Originally posted by Moses
Thanks Thom,
Find a friend with the Mitchell or Alldata manuals, or someone with the Bosch DME book. I did a search on google and came up dry. Adrean Streather has the Bosch DME manuals, maybe if you ask reaaaallly nicely. He bailed my a$$ out when I was doing the smog dance on my car.
Old 06-16-2003, 10:43 PM
Metal Guru
911nut's Avatar
Moses, apparantly replacing your 3.0 motor was bad ju-ju
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 06-17-2003, 04:39 AM
Embs's Avatar
Moses, I don't know if this helps but it is a 993:
Old 06-17-2003, 04:55 AM
Embs's Avatar
Don't feel bad Moses, my Varioram system has never worked either!
Old 06-17-2003, 04:59 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Mitchell has very good wiring diagrams, a little less confusing than factory manuals i think.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-17-2003, 06:03 AM
I find it interesting that the pinouts are different, even though the connectors are the same. So much for plug-n-play with that 993TT engine...
Old 06-17-2003, 09:00 AM
The resonance flap on both pinouts looks like the control, but do you know what kind of signal it delivers ? You may need to be checking a duty cycle (PWM) instead of steady voltage.
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 06-17-2003, 09:05 AM
Moses, didn't Timmins have the motor in one of his cars and running?
Old 06-17-2003, 09:09 AM
Moses's Avatar
This brings up a second question. There is no data port connected to the DME. How difficult would it be to connect one? It would sure make diagnostics easier. As it is now, I have to hook up a voltmeter and go for a high RPM drive to check the signal. Anyone have a data port on a 3.6 transplant?
Moses's Avatar
Yes. So did I. But I never had a functional varioram.
My ex-mechanic killed the DME that came with the car. Timmins sent a '95 DME replacement that he assured me would operate the Varioram. It did not. So I bought a second DME from Timmins (a '96 V-ram DME) This one also does not trigger the Varioram. Most likely conclusion; my ex-mechanic may have wired the harness incorrectly. (He may be an ex-Jaguar electrician double agent still bitter about WWII. Or he may simply be an idiot. He had my car and my money for 6 months and never got it right.)
Old 06-17-2003, 09:16 AM
Embs's Avatar
Moses,
Call Steve Weiner or try and stir him up over on rennlist. He will have some good info. He has (correctly) done more of these than anyone else.
Old 06-17-2003, 09:57 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Moses,
pin 1 is the correct pin on a 993 VarioRam. It should cycle the resonance flap when you turn on the ignition and start the motor. No need to run the motor under load and >60% throttle.
You should be able to hook up a simple volt meter to the wire connector that runs to the vacuum solenoid valve and be able to watch a signal. No duty cycle - just either nothing or 12V. If the signal is there but your flap does not move you have a vaccum line problem.
Adding a diagnostics port should be not all that complicated. All you need is the round multi-pole (17?, don't have my shop manual open) connector and some wiring from under the drivers seat to the connector. As far as I remember you need to wire ground, +12V, K-lead, L-lead and that's it. I was thinking of adding one myself but the testers (Bosch hammer) are so expensive that I don't see myself ever buying one just to play with it.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 06-18-2003, 08:52 AM
Moses's Avatar
Thanks Ingo. So if I get it hooked up correctly I should be able to watch the valves actuate on startup, right. I don't suppose there would be a Euro/US difference in this startup cycle. I have a friend here at work with a 993 V-ram. I think I'll ask him to start his car for me so I'll know what I'm looking for.
Old 06-18-2003, 09:31 AM
On my car, the resonance flap 'flips' when I turn the key on - without starting the engine. My mechanic told me that it's part of a self-test the DME does. For the 'normal' 3.6 engines, this comes on @ 5100RPM. If it doesn't come on when you turn the key, it will not come on @ 5100. I've only seen one other 3.6L conversion in person which this was hooked up correctly. FWIW, having the resonance flap hooked up correctly maded 12hp on the dyno.
Old 06-18-2003, 10:05 AM
Moses's Avatar
Originally posted by widebody911
... FWIW, having the resonance flap hooked up correctly maded 12hp on the dyno.
I'm a little compulsive about some things. If I don't hook up the Varioram, then that big silver intake system on my motor is merely decorative. And 12 HP is, after all, 12 HP.
Old 06-18-2003, 10:37 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
quote
I am not sure of all this lingo...but I have complete faith that Harald and Ingo hooked mine up correctly.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-18-2003, 10:40 AM
It made 12hp on my non V-Ram engine. It would make more on yours.
Old 06-18-2003, 10:43 AM
