tx996tt's Avatar
ITB Sizing- Recommendation
Hi All,
Looking for recommendations as I am rethinking carbs vs ITBs. Initially the plan was to build a 3.0L running 46mm PMO carbs. Following are build specs:
Stock crank 70.4mm
JE 10.5:1 Pistons
Twin Plug 39mm heads
Web Cams 120/104 cams. Close to GE 60 specs but on 100 degree lobe center vs 102
JBR Twin Plug Distributor
Twin MSD ignition boxes/ coils
ARP Head / Rod bolts
1 5/8" headers
Dansk 2-2 Sport
All parts purchased except carbs. PMO has now released their line of ITBs which look great. Couple questions / concerns:
1. ITB sizing 40mm vs 46? Plan to spin the engine around 7500. Concerned 40s too small and 46s too large especially if forced to tune Alpha N
2. Tight LCA cam and lack of manifold pressure for tuning. Options: tune hybrid Alpha N (throttle position) with manifold pressure reference?
3. Option 3 - stay with carbs
Appreciate any input /feedback
Euro SC 3.0 Twin Plug PMO ITBs Haltech 750 DC43-106 Cams
996TT Protomotive 24/18g
Past: 964 C2 Coupe, 16 GT350 e85, BMW K1200S
Old 12-19-2023, 10:49 AM
Following
Old 12-19-2023, 11:05 AM
Recommend calling William Knight.
'81 911 SC
'03 BMW M3 (Sold)
'64 VW Beetle, 2332, 48 IDA (Sold)
Instagram: @j_smallwood
Old 12-19-2023, 11:13 AM
Bill Verburg's Avatar
Originally Posted by tx996tt View Post
Hi All,
Stock crank 70.4mm
JE 10.5:1 Pistons
1 5/8" headers
Dansk 2-2 Sport
conventional wisdom is to go 40mm for 3l @7500
You want to keep the velocity up for throttle response, 46s will drop the flow velocity by 32%
even for 3.2s the 40s are the better way to go
Bill Verburg
Old 12-19-2023, 11:53 AM
New-ish 911SC Targa Owner
pampadori's Avatar
distributor instead of COPs?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 12-19-2023, 01:09 PM
It's a 914 ...
stownsen914's Avatar
Keep in mind that it's common with ITBs to have the throttles larger than the base/port diameter, with taper in between.
Old 12-19-2023, 05:24 PM
Hi,
My engine is almost exactly the same as yours with the same camshaft profile only it’s a 3.2 short stroke with RSR Mahle p/c’s.
It has 46mm PMO ITB’s and I am very happy with the way it performs.
Here’s data from the hub dyno:
Old 12-19-2023, 06:00 PM
tx996tt's Avatar
Thanks all - very much appreciate the input.
Classic 911 - nice numbers :-) - thanks for posting the dyno results
Old 12-19-2023, 07:31 PM
