AME AME is offline
AME's Avatar
Question No turn signals (indicators)
My'69 911 turn signals have taken a permanent vacation; there is no life from neither the turn signals nor the hazard lights.. I'm a complete novice regards electrical faults so all I've checked is that all fuses are fine and all bulbs and wires to the turn signal housings are ok..
I thought perhaps the relay is broken - but I've no idea where to find this ... any ideas people ?
/Martin
'69 911s
Old 06-17-2003, 11:52 AM
I would rather be driving
jpnovak's Avatar
The relay is behind the oil pressure/temp guage. Its a small black box looking thing. Easy to get to.
Pull it out, pop off the cover and clean the contacts. Worked wonders for my car.
Old 06-17-2003, 11:55 AM
AME AME is offline
AME's Avatar
Yikes, that was a quick reply !
Lovely - I will go relay hunting tomorrow .. thx so far
/Martin
'69 912 with tired '68 911S 2.0 smoker
Old 06-17-2003, 12:11 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
AME...you will get that here! Great stuff!
You may be Gruppe B material...search for it!
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-17-2003, 12:12 PM
jpnovak's Avatar
AME, Welcome to the board. Most topics will get you a quick answer.
Just to clarify. You will want to clean the contacts that open and close for the relay. These are what make the system "Blink". If that doesn't work check the connections in the stalk switch and headlight switch.
Yep, you may qualify for Gruppe B.
Use the Search button in upper right hand corner to find many answers in the archives.
Old 06-17-2003, 01:04 PM
AME AME is offline
AME's Avatar
Finally had a chance to stick me head behind the dashboard .. alas nothing that looked like a relay ... all that I could see is the 'rear workings' of the lightswitch and ignition... above those again there would seem to be a casing covering what would be the bottom of the gauges ...
btw... I did search for "gruppe b" but that left me none the wiser ... anyone care to enlighten me ?
Martin
Old 06-21-2003, 12:52 PM
