Alignment Issue
Hi All, my recently purchased SC had 12 year old tires so had some Michelins put on which really improved the ride. I took it to the most reputable tire shop in my area.
Regarding the alignment, they spent a few hours on it but I needed to pick it up, so they said to bring it back as they wanted to keep dialing it in. Their systems showed that it was off significantly to start. I brought it back a few days later, and they said they did everything they could and that it is within spec and much improved, but my steering wheel is now cocked 20 degrees or so to the left when driving straight. It was not like this prior. Anyone run into this issue? |
They need to reset the front toe to recenter the steering wheel.
Senior Member
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
PCA Member since 1988
A proper alignment should put the steering wheel centered. If they didn't do that, I question the quality of the alignment you got.
Center the wheel and then turn it fully left and right to see if it's the same number of turns (and fraction) each way. If it is the same number of turns from center, then they didn't align the toe correctly.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
cycling has-been
Take it to a Porsche shop.
The chain tire stores are limited in Porsche knowledge and mechanicals.
73 911T MFI, 76 912E, 77 Turbo Carrera |
If they messed with it a lot, likely the corner balance snd ride height will need to be redone by someone with the knowledge of old 911s.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
So as others also already recommend: Go to another shop as it's a simple "no go" that they gave you an "aligned" car with a such bad "over all toe" setting. I would even guess that the alignments on all wheels where done in a same "accurate" way. ;-) Not mention if that has been done in the same bad way on the rear wheels where no steering wheel logic can "center" the wheels like you can do on the front. Means within a short time your rear tires then will be erased down to "slicks".
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
