Flywheel- resurface or replace?
So I pulled the clutch last night before getting my motor put on the stand, and the flywheel is in pretty rough shape. I've got a rebuilt gearbox and new clutch on the way, so at this point thinking I'm probably better off just replacing it... but interested to hear if anyone has experience with just having theirs resurfaced or any recommendations- thanks!
Old 01-03-2024, 08:52 AM
Has to be measured to see if it is in spec or warped et can’t eye ball it. If you have a decent machine shop that won’t lose your parts or take 6 months I’d try that route first unless your after something lighter or just have money to burn.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 01-03-2024, 12:22 PM
Catch, you take meat off the flywheel you loose life on your clutch.
Bruce
Old 01-03-2024, 06:44 PM
Bruce, can you explain how that would happen? I'm not disputing it, I just want to understand the mechanics. I am replaceing the pressure plate and clutch disc on my '88 and decided to spring for a new flywheel, even though mine looked to be in great shape. Your comment makes me feel better about spending the $$!
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 01-04-2024, 06:10 AM
shoooo32's Avatar
I check them for runout with a mag base and dial indicator while still bolted to the crankshaft - if they run true I scotchbrite the surface and send them. If they're warped, I buy new. John Walker recommended not to bother resurfacing (machining) them, and I took him for his word.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 01-04-2024, 06:30 AM
It has to travel a wee bit farther is my guess
Old 01-04-2024, 08:23 AM
Checking runout with it still bolted up actually makes a lot of sense, I'll give that a shot before I pull it off. I tried giving it a quick pass with scotchbrite last night and it cleaned up pretty easily actually and I don't see any signs of excess heat so it might end up being totally fine.
If not I guess that'll be my excuse to get a lightweight flywheel
Old 01-04-2024, 09:12 AM
shoooo32's Avatar
The RSR style flywheel is the sweet spot for a street car in my opinion. It makes the car more playful without being too finicky for daily driving/traffic.
-Tony
AchtungKraft #002
Old 01-04-2024, 11:02 AM
The original specification for the G50 flywheel was suggested not to be cut but replaced.
Factory suggestion.
Bruce
Old 01-04-2024, 03:42 PM
I shipped my 930 flywheel with my cylinder heads to Craig (CGarr) to eyeball it… he skimmed it with a cleanup pass and it’s been trouble free so far. Not sure if the 930s have more or less meat than the G50s so YMMV.
Ken
1986 930 2016 R1200RS
Old 01-05-2024, 06:36 AM
PCA Member since 1988
Bruce
Bruce, I don't understand that either. If you flatten the whole flywheel, then the relationship of the clutch to the flywheel surface doesn't change, so the clutch shouldn't work any differently. At least for small clean-ups, say, .005" to .010".
Or is there something else affecting it?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-05-2024, 11:20 AM
