bose213's Avatar
Wires in the left side of the trunk
Hello.
What are these cables? 911sc 1979 sportomatic
Arthur.
Owns a Porsche 911sc 1979 Sportomatic.
Old 01-11-2024, 01:43 AM
PCA Member since 1988
You mean the engine compartment, rather than the "trunk." Yellow is usually the starter circuit. Hopefully, someone else with the correct wiring diagram for a '79 Sporto will jump in here. If not, hook up a voltmeter to the connector and see if you get 12volts when you crank the engine. A branch of the yellow wire goes to the fuel pump relay, and IIRC, a branch of the yellow wire also connects to the Sportomatic relay.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-11-2024, 02:39 PM
