3.2 Flywheel pilot bearing question
I'm a bit perplexed here, looks like I may not have the correct 3.2 flywheel? I don't see how I get the 3-bolt pilot bearing on the crankshaft and then fit this flywheel, which looks like it might want the press fit bearing. I sourced the used flywheel from a local tech and I just assumed it would be the right one as he helped assemble the engine. What am I missing?
Schleprock
That’s a later 3.2 flywheel with a lightly pressed in pilot bearing. It’s a 240mm flywheel for the G50. The 3-bolt flywheel is a 225mm wheel for the 915
Kevin L '86 Carrera "Larry" |
Bummer.... they're both 3.2, just not the right 3.2
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Schleprock
Let me know if you need the 915 style after corresponding with Scott (good guy, I agree wholeheartedly) since I have a good used one from my ‘86 I was considering selling on the classifieds. I have a new one on the shelf waiting for my engine to get reassembled by me someday. So the old flywheel will just sit on the shelf for years
Bill |
I think I also may need the throwout bearing spacer/shim. I can't find a part number for that as a separate item. I have the circlip part number, but not the shim.
Kevin, I sent you a PM on the flywheel, looks like I will need to find one. Bill |
Schleprock
I sent you an email detailing the flywheel I have. Let me check my collection of spare parts to see if I have the spring shim for the release bearing. I know I’ve got an old release bearing on the shelf so I probably do have the shim too
Old thread I know, sorry... so the older 915 bearing had an outside diam of 50mm.
Looking up the part number for a later 3.2, I get 931 102 111 02 and a quick google gets me to https://www.sp-spareparts.com/en/p/6202-2rsr-c3-fag which shows an ext diam of 35mm. Does that sound about right? I just picked up a 993 style bearing to use in a 3.2 flywheel on a crankshaft that doesnt have the 3 threaded holes to mount the original style bearing. The 993 style is 999-052-169-00-OEM and has a 50mm outside diam. Just trying to understand all the different options over the years.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
