911SCRVA's Avatar
Perplexed: Hard Oil Line Bracket Question
I replaced my hard oil lines a year ago. Recently I removed the hard oil line brackets. Just now as I'm trying to remount the brackets, the factory bolt will not securely fasten into the bracket welded onto the car (sorry, I don't know the technical words).
However, if I use a different (non-factory) bolt, it will securely thread into the mount.
What happened?!
What should I do from here? Any solution that doesn't require me to remove the hard oil lines from the car is preferable.
Thanks for your help.
Old 02-08-2024, 09:51 AM
I can see you have rubber sheets on one side of the pipes. Are the sheets on both sides.
I've seen the sheets wrapped around the pipes.
Old 02-08-2024, 10:20 AM
911SCRVA's Avatar
Yes, the rubber wraps all the way around the line
Old 02-08-2024, 10:24 AM
Is this down the side where the rocker panel is? Some of those bolts are longer and have a spacer that goes between the rocker and the bracket, if I remember right. If you get rid of the rocker panels you have to get shorter screws (6.3 tapping), I distinctly remember doing this for mine when I removed the rockers.
1982 911SC
Old 02-08-2024, 10:28 AM
You have stripped the threads . . using the other bolt with a different thread pitch seems temporary at best.
Old 02-08-2024, 10:29 AM
911SCRVA's Avatar
Yes, this is where the rocker panel goes. Thank you. Now I'm remembering the proper order. I need to reinstall the rocker panel, THEN remount the brackets. Rookie mistake.
What if I did strip the part welded onto the car that mates with the bolt?
Old 02-08-2024, 10:38 AM
Run an appropriate size tap thru the welded nut . . if that doesn't help you may have to go one size up and get a larger bolt and tap
Old 02-08-2024, 11:03 AM
To retain the use of the original sheet metal bolt I slide a speed nut over the tower that is welded to the tub. When installed it’s not seen. A typical speed nut is found on the engine fiberglass shroud, but might need trimming.
Old 02-08-2024, 11:48 AM
Titanium User
Slip a threaded speed nut over the factory tab
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 02-08-2024, 12:12 PM
911SCRVA's Avatar
When you and gled49 say speed nut over the welded factory tab, do you mean between the nut and tab, or on the other side of the tab? I may not understand how the speed nut works.
Old 02-08-2024, 06:02 PM
The body tab has nothing more than a hole in it. The sheet metal bolts into the hole. Slip a speed nut over the tab or even behind it.
Old 02-08-2024, 07:11 PM
