Perplexed: Hard Oil Line Bracket Question
I replaced my hard oil lines a year ago. Recently I removed the hard oil line brackets. Just now as I'm trying to remount the brackets, the factory bolt will not securely fasten into the bracket welded onto the car (sorry, I don't know the technical words).
However, if I use a different (non-factory) bolt, it will securely thread into the mount. What happened?! What should I do from here? Any solution that doesn't require me to remove the hard oil lines from the car is preferable. Thanks for your help. ![]() ![]()
I can see you have rubber sheets on one side of the pipes. Are the sheets on both sides.
I've seen the sheets wrapped around the pipes. |
Is this down the side where the rocker panel is? Some of those bolts are longer and have a spacer that goes between the rocker and the bracket, if I remember right. If you get rid of the rocker panels you have to get shorter screws (6.3 tapping), I distinctly remember doing this for mine when I removed the rockers.
1982 911SC |
You have stripped the threads . . using the other bolt with a different thread pitch seems temporary at best.
What if I did strip the part welded onto the car that mates with the bolt? |
Run an appropriate size tap thru the welded nut . . if that doesn't help you may have to go one size up and get a larger bolt and tap
To retain the use of the original sheet metal bolt I slide a speed nut over the tower that is welded to the tub. When installed it’s not seen. A typical speed nut is found on the engine fiberglass shroud, but might need trimming.
Titanium User
Slip a threaded speed nut over the factory tab
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
When you and gled49 say speed nut over the welded factory tab, do you mean between the nut and tab, or on the other side of the tab? I may not understand how the speed nut works. |
The body tab has nothing more than a hole in it. The sheet metal bolts into the hole. Slip a speed nut over the tab or even behind it.
