emarsh's Avatar
SC Dyno chart?
My 1979 SC seems to come on the cams at about 4k rpm. Is this normal? Does anyone have a dyno chart of for one of these?
1979 911 Targa
406ci Chevy powered '88 Fiero GT
Turbocharged 2000 Suzuki Hayabusa
1990 Buick Reatta
Old 06-18-2003, 09:17 PM
banjomike's Avatar
my 79 3.0L motor definately starts hitting that sweet spot at 4k. I think that is very typical.
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 06-18-2003, 11:16 PM
tbitz's Avatar
I think this is from the Bentley manual.
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 06-20-2003, 11:00 AM
tbitz's Avatar
Try again....
Tony
Old 06-20-2003, 11:03 AM
Formerly bb80sc
Vipergrün's Avatar
Emarsh....any mods to your car? Adding SSI's and dorking with the timing advance and mixture will broaden the range. Before doing any of these it was almost as if I had turbo lag until 4K
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 06-20-2003, 11:32 AM
Senior Member
Superman's Avatar
Yep, very normal. If you advance timing to 35 degrees full advance, the torque curve will flatten a little. I also have installed different cams (20/21, but 964 cams are similar) which have the same effect (flattening the power curve). Yes, your experience is normal. Poor power below about 3500 rpm, screams like a banshee above 4000.
Mocha 1978 911SC. "Coco"
Old 06-20-2003, 11:42 AM
