SC and cigarette lighter voltage meter
Hey all....
I am dealing with some funky electrical/battery related issues; and I would like to see if my alternator is performing properly. I can go into the “funky” in a later post if needed; but that is not what the initial post is about here. I’d like to get one of those voltage meters that I can plug into the cigarette lighter, and see if I have 14.2V (or less) to perform my investigation; but I am thinking that there is a “fit” issue given the euro-size of this (non-fused!!!!) cigarette lighter. Can someone give a recommendation on type/brand based on experience? I’d like to grab one from our host if possible, but it doesn’t look like this is available on our site.... SO: suggestions?
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
the "INNOVA 3721 Battery and Charging System Monitor" works in the cig lighter of my '81 SC. $25 from amazon, sadly our host does not sell this.
It's not so much that some products will fit and some won't, but that most anything will be a little loose. For instance my Bluetooth FM transmitter works fine until I hit a big bump and it gets bounced loose.
'80 SC Targa Avondale, Chicago, IL |
83 911 Production Cab #10
Have been using this one for 5 years with no problem.
$18 delivered https://www.innova.com/product/detail/3721/Battery-Monitor
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
This was a top seller on Amazon but didn’t fit my car (80SC). Probe was too small: https://www.amazon.com/LIHAN-Charger-Display-Voltage-Current/dp/B01M9IKYVH
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
I also needed to see the alternator output. I bought the lighter voltmeter off of eBay. Sorry no seller info, etc. It was a little loose but it works. As can be seen I ended up using the radio delete plate to install a voltmeter. They match nicely.
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
Looks factory - I like it!
If what you plug in is loose, just shim it. Depending on design, might use copper or brass shim stock. Ground to ground.
Been here a while
I’ve found with the loose accessories, often just wrapping the plastic area with electrical tape will stop the wobble and the electrical connection becomes rock solid.
If you read the updates about the shims some guys made they eventually caused a short.
looking for 1972 911t motor XR584, S/N 6121622 |
the oversized bit? is that a euro standard size?
ie - could one order a proper sized unit from Europe? |
Cig lighter sizes
1) 1980 Porsche SC Coupe - dia = 0.867" 2) 1994 Jaguar XJS convertible - dia = 0.816" 3) 2014 Ford F150 - dia = 0.786" (cell phone charging cord) I think they would all fit all the vehicles. The charging cord would be a bit loose but still work.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
![]() This is not what you asked about, but it was my solution. I wanted something that looked factory. The cigarette lighter option is certainly cheaper, but just did not have the look I wanted for my 911. I have a 85 Carrera, and I always hated the stupid shift light. This eliminated the light, and serves a real function, and looks 100% factory. It is what the factory should have done.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
82 911 SC - Ancora Imparo
AINOPE Car Charger Adapter, Dual QC3.0 Port 6A/36W Fast USB Car Charger https://www.amazon.com/gp/product/B08138GVMH/ The girth was fine, but the length was a little underwhelming. I love the look; simple, red voltmeter with 2 USB ports. Can anyone else recommend something similar but with enough length to work correctly in our cigarette lighters?
Ethan 1982 911 SC - Wine Red Metallic Coupe |
My plan is to solder an extra blob on the end to make it long enough to contact. Doesn't seem like it needs much additional length. |
Analog Air Cooled
I swear by a digital voltage meter. I got one of Amazon that another member showed here. Been chasing a elect overcharge gremlin and a voltage reg issue. Replaced a new Velo ALT, and was a little better. Annoyed that a $500 didn’t solve my issue I kept pulling fuses and isolating.
Then when I put my AC on, I pt really pulled voltage and the radio clipped.. So I moved my seat ( there on the same fuse 25amp circuit ) and nothing. Unplugged the seat power to drivers side and all is better than my car ever worked. 13.9-14.2 in every way for over an hour. If you have a 3.2, check those seat motors and switches. After 35 years, she probably deserved a new alt. Or that’s what I Tell myself..
86 Targa 91 964 13 6 SPD Cayenne Last edited by Hotshot; 08-29-2021 at 10:10 PM.. |
Palumma 24W/4.8A Dual USB Car Charger, 12V to USB Outlet with Cigarette Lighter Voltage Meter LED/LCD Display Battery Low Voltage Warning (Black)
by Palumma Learn more: https://www.amazon.com/dp/B0773BYS6P/ref=cm_sw_em_r_mt_dp_S95S79RN6ARY2V8961ES?_encodin g=UTF8&psc=1 |
