What is the best 915 transmission
Goodmorning my fellow Pelicans,
Since everyone is always talking about 915 vs G50, I was wondering if there is a big difference between the several 915's that exist. Is there one that is favourable or are the differences negligible. I for instance have a 915/61 in my sc and saw that it was also used in the 911s, 3.0 carrera's and the early sc's with US serial numbers.
Regards,
Gerko Hoek
1978sc
Old 06-05-2004, 12:19 AM
marcesq's Avatar
After '73 boxes are about the same, however, the 915/61 box (which I have as well) has a higher second gear than the 915/63 box which came with the 1980 SC. This means that your car will pull better in 2nd than a comparably equiped 80 or older SC.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 06-05-2004, 06:06 AM
Bill Verburg's Avatar
915/67, 915/69, 915/72 are the last & strongest 915s, they also include a factory cooler. Gearing can easily be changed to suit. If selecting a trans from scratch start w/ the best for your purpose, whether it be for lightness or for strength, or a combination.
915/67
Bill Verburg
Old 06-05-2004, 06:31 AM
marcesq's Avatar
Hey Bill . . . is the oil cooler also on US versions?? Thought they were only on the Euro models.
Old 06-05-2004, 06:37 AM
ROW, but Bruce Anderson once told me he saw a few on some Texas cars.
Bill Verburg
Old 06-05-2004, 06:44 AM
marcesq's Avatar
LOL . . . somewhere I read that everything is bigger in Texas.
Old 06-05-2004, 06:48 AM
MRM MRM is offline
What is the difference between ROW and US 915s? I have an 84 ROW but second gear has been almost munched. I should have a cooler on it, shouldn't I? Is the gearing different for ROW and US cars?
MRM 1994 Carrera
Old 06-05-2004, 07:12 AM
creaturecat's Avatar
row cars came with the cooler fifth gear is slightly higher for some years due to the increased horsepower
Old 06-05-2004, 09:02 AM
arrivederci's Avatar
So for an early car with a 3.6L transplant, the strongest ones are likely the best starting point. Which gearing would you say is best for track purposes? My 7:31 is actually pretty nice for the track right now. With the smaller tires on my car, I never get below 3rd gear and I almost top out in 5th gear on longer straights. But then again, that's with only 170-ish hp. Nowhere near 3.6 territory.
- '72 911T
- '81 911SC Euro
Old 06-05-2004, 09:07 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
What's involved in maybe trying to put an oil cooler on a 915 that doesn't have one?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-05-2004, 09:14 AM
are these trans easy to find and how much do they go for
Old 06-05-2004, 12:52 PM
Grady Clay's Avatar
What is the availability of the pressure lubed 915 transmissions?
BA says “When these oil pumps were used in the production cars, they were used just to recirculate the transmission lubricant around to be sure that it would provide proper lubrication to all gears.” Everyone should read Chapter 7 in Bruce Anderson’s book (available from our host.)
© 1996 Bruce Anderson
These were used in RSRs and other 911s.
Best,
Grady
Old 06-05-2004, 01:29 PM
The cooler pumps Grady pictured were also used on some RSs, All 915 have the bosses etc to mount them. Unfortunately as w/ so much else, they are NLA, last ones I saw went for ~$23300 just for the parts. They also used any internal spray bar
The easiest way to add a cooler these days is an electric sump pump like this, which has the plumbing short circuited temporarily
Bill Verburg
Old 06-05-2004, 03:23 PM
KobaltBlau's Avatar
That's a neat DIY setup Bill, I haven't seen one like that before. It would be interesting to run a trans. temp sensor to see how hot the fluid gets.
Andy
Old 06-05-2004, 06:52 PM
915 Euro
915/67
Bill,
I have a 915/67 cooler and LSD. Any upgrades you would recommend since this is the strongest of the 915's? I don't want to spend the money outside of synchros and dog teeth if the value is not material.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 02-10-2024, 09:59 AM
Schulisco's Avatar
Keep in mind that Porsche changed the housing material of the 915 in 1978 from magnesium to silumin/aluminium...the more powerful the engine the more the aluminium case makes more sense...
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 02-10-2024, 01:23 PM
Aluminum diff housings usually have a loose pinion bearing outer race these days. I see less of that with mag cases. Time takes it's toll.
206 637 4071
Old 02-10-2024, 04:16 PM
For whatever it’s worth.
My stock 1981 915 with factory lsd had no issues with my 993 3.6 conversion. I did the conversion around 50k miles ago.
I’m in the middle of a 3.8 build and decided to rebuild the box and throw all the good bits at it.
915 rebuild
Wevo Bearing Retainer
Wevo External Shifter
Wevo Solid Shift Joint
Wevo Reinforced Side Plate
RSR Spray Bar Kit
Wevo Internal Gate Shift Kit
Wevo Transmission Mounts
Wevo transmission pump
Setrab transmission cooler
964 axles and machined stubs
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 02-10-2024, 08:25 PM
Originally Posted by sundevil64 View Post
Bill,
The one big advantage of the last g case trans was the steel girdle that stabilized the shafts, the Al. case trans doesn't have that. A n Al. cas can have one added but the case needs to be machined for it
best place I know of to add the steel girdle is Wevo
or you can add all the little later improvements to the Ng. case version.
It doesn't seem to be much of an issue unless a 3.6 or bigger is used and of course the more miles the more wear of all kinds
Bill Verburg
Old 02-11-2024, 10:27 AM
-Levi- did just that, see above
PS Levi any progress?
Bill Verburg
Old 02-11-2024, 10:33 AM
