nestorjw's Avatar
Send a message via AIM to nestorjw
Value of 7/8" Fuchs
I bought a set of 16x7/8 inch fuchs that came off a 944 Turbo, I had them on my 911SC until I decided to have them refinished. They are at Al Reed right now, so I will get them back like new, anodized lip, black center. I just was wondering what these wheels are worth? I have one other option for wheels and I want to know what I could get for these. I might just sell the 7"s so what would those be worth alone? Thank you all!
Jeff
83 SC, Guards Red.
Old 06-20-2003, 04:01 PM
COLDBASS's Avatar
FWIW,
I recently purchased a set (2) of 16x7 944/951 Fuchs (951.362.115.00) for $400.00. No center caps or lugs.
Good condition, black paint was faded.
Hope this helps..
Bob
Old 06-20-2003, 04:27 PM
Administrator
Jack Olsen's Avatar
The 8's are useful to 911 owners, to put in the front. I don't know of any notable use for the 7's.
Old 06-20-2003, 05:18 PM
Elombard's Avatar
If you had them on an SC i saw a nice set bid up to $1600 I think on Ebay a few weeks ago. I would think a set of 7,8s that are refininshed and have the 911 off set will get $1200 to $1500. I like my Fuchs faded so I would only give you $500 :-))
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-20-2003, 05:56 PM
Information Junky
island911's Avatar
I believe the offset of the spokes allows clearence for some of the bigger brake calipers.
Old 06-20-2003, 06:15 PM
Correct..even though the 911 and 944(951) 7" Fuchs have the same 23.3 mm offset..the 951 piece has better brake clearance for the big calipers.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-21-2003, 06:04 PM
MBruns for President
JeremyD's Avatar
If the 8's are Porsche Part # 951 362 117 00 16 x 8 Fuchs then they are worth some money. I think wheel enhancement quoted me $1200 for a set = Earnie's alloys - $1600. I bought a set for $700 and thought I got a steal at the time. 16 x 8 (As above) and 16 x 9's are about the largest stock wheel you can put on the Carrera. Except of course if you are Jack with his custom fuch/lindsays in 17" config.
Old 06-21-2003, 08:13 PM
nestorjw's Avatar
So the 7" fuchs have the same offset as the 911 wheels? So basically it is the same, just allows bigger calipers? So the 7"'s could be used on an SC and it wouldnt be any different than the 911 ones? THanks for all your responses!
Jeff
83 SC, Guards Red.
Old 06-22-2003, 02:45 PM
Eric Coffey's Avatar
Yes, Yes, and Yes!
Old 06-22-2003, 03:21 PM
If you have the 7's and 8's off a 944 turbo, I don't know how you'll use them directly on a 911. The 8's, as mentioned before, will go up front. I have these on a Carrera. If you put them on the back, the offset may fit, but your car will have more tire toward the inner wheel well and lots of gap at the fender lips. Basically, you have two sets of wheels that can be used up front. Now you just have to pick up a set of 9x16's for the rear.
Old 06-22-2003, 07:02 PM
Don't get us started on wheel fitment! What you are looking for is the difference between offset and backspacing. Are you looking for caliper clearence or fitting as much rubber as possible under the fender?
Old 06-22-2003, 07:57 PM
Information Junky
island911's Avatar
Originally posted by 89911
. . .The 8's, as mentioned before, will go up front. . .
just because they will fit up-front, doesn't mean you must use them up-front.
If you use the set of 951 Fuchs rims on a 911, it will, for the most part, appear to have 6's & 7's with spacers.
Old 06-22-2003, 08:29 PM
nestorjw's Avatar
In that case anyone want to buy some 7" fuchs, just refinished turbo look?
Jeff
83 SC, Guards Red.
Old 06-22-2003, 09:02 PM
