No one tells you this part… (longhood latch panel install- help!)
Hi everyone!
So there are plenty of threads with information on removing a shorthood latch panel, but none that tell you how to get the new longhood one in. I feel a bit dumb for asking, as the process should be obvious, but someone here undoubtedly has the answer. (No, installation is not the reverse of removal…) It wasn’t that hard to remove the old one, just time consuming grunt work, but that went fine and everything cleaned up well. I have the following observations: -I considered if the panel could slip downward into place from inside the frunk, but there are several reasons this won’t work. The big one being that it isn’t possible to slip the bottom of the new panel over the outside of the suspension pan, which has to happen. The battery to chassis grounding post also appears to be in the way. -It is also impossible to insert the panel from the outside, as anyone who has done this will know. What am I missing here? Some pics. All cleaned up and ready for the new panel: http://forums.pelicanparts.com/uploa...1709156332.jpg Its not going in this way as far as I can tell: http://forums.pelicanparts.com/uploa...1709156332.jpg |
Might need to straighten out the lips one side and bend it back once the panel is in. I always did it along with the suspension pan, never tried it by itself. Good luck.
It’s easiest to open up the ends like John said, if I remember correctly you need to notch the top ends ( Channel) so they fit underneath the inner fenders. Also have to cut or drill spot welds so the bottom corners of the new panel slides in. If I remember correctly getting the bottom of the new panel in correctly is the painful part.
Other than doing a full pan replacement the suggestions thus far are good.
A small cut at the top and bottom of the fender liner and basically splay the inner fenders outward far enough to slip the panel in should/could/might, hopefully, do it. Or, go all in... http://forums.pelicanparts.com/uploa...1513041566.jpg http://forums.pelicanparts.com/uploa...1513041566.jpg |
Thanks everyone!
I thought it might require some additional surgery, but needed to hear it from those who have been there before I start cutting. I did consider opening up one end, as that will be easy, so that's what I'm going to do. Quote:
Pan is OK, so I'll go for a little nip and tuck instead. Thanks for the pics and info! I've studied the first couple pages of your build thread backwards and forwards, so those pics are very familiar! . |
Now - speaking of test fitting the panel, I can't recall how much of the new sheet metal you have on hand, but don't succumb to the temptation to weld in that new panel without test fitting it with your hood, and the bumper seal, and the bumper, and the fenders. And the turn signals and the horn grilles. This is the critical point in the project where the fit (or lack thereof) of all these components is determined. Yes, there is a certain amount of adjustability with everything but the one thing that can't be moved once installed is that damn channel that holds the bumper seal. And it basically needs to be within a few mm of the correct position or else there will be gaps and misalignment of the bumper seal. http://forums.pelicanparts.com/uploa...1709211628.jpg The hood and fenders need to be positioned with respect to the cowl and doors, and each other, so imagine if you get those perfectly aligned with all the gaps where you want them, and you've already committed to a position of that bumper seal. It's not just the vertical position that's important, it's the fore/aft position. Everybody struggles with this, even the factory restoration department. Even Singer doesn't nail it on every car. |
I've test fit my new fenders, and they are really not great so I will have some serious work to do there to get the gaps right. I'll surely be needing advice! |
Can’t stress Jonny’s point about fitting enough. Clamps, tape, clekos, screws… use whatever you need to get the whole thing put together and fit to your liking before securing anything. Even perfectly fit parts have a way of shifting, distorting and otherwise conspiring against you later on.
It’s kinda like home building: if you want the tile to look good start with the framing. |
On positive note, and to follow up the original purpose of this thread, I did a little metal surgery and the latch panel went in with no drama. Screwed temporarily in place until I fit the rest. There are probably multiple ways to do the same thing but here was my solution: http://forums.pelicanparts.com/uploa...1709368046.jpg http://forums.pelicanparts.com/uploa...1709368046.jpg http://forums.pelicanparts.com/uploa...1709368046.jpg |
I’d love some advice on the fenders, “while we’re in there.” I bolted up the left fender with 5 bolts in it including the one in the cowl closest to the door, and as most people find out the hard way, a repro panel just isn’t going to match a hand-built car very well. I can probably massage the fender to cowl area to sit better somehow (haven’t ever done it, so I’ll need some help!) Gaps I can weld up or shape. Its at the front of the fender I’m most concerned— the flange on the outer fender that mounts to the inner fender deviates greatly in it’s contour at the very front, and the fender sticks out past the latch panel. Having never worked on a longhood or conversion like this, it is hard for me to know what is correct, or can be corrected, or is just plain wrong. I’m seriously considering welding light boxes to my shorthood fenders instead, but that won’t be a piece of cake either.
Here you see the difference in these contours where the fenders meet: http://forums.pelicanparts.com/uploa...1709369257.jpg http://forums.pelicanparts.com/uploa...1709369257.jpg And the rest of the poor fit: http://forums.pelicanparts.com/uploa...1709369564.jpg http://forums.pelicanparts.com/uploa...1709369564.jpg http://forums.pelicanparts.com/uploa...1709369564.jpg http://forums.pelicanparts.com/uploa...1709369564.jpg http://forums.pelicanparts.com/uploa...1709369564.jpg http://forums.pelicanparts.com/uploa...1709369564.jpg http://forums.pelicanparts.com/uploa...1709369564.jpg |
You have a pm
The fit of the front fenders was the number one reason I decided to keep my car’s original fenders and weld in the light boxes. I figured that even if the extensions were crummy and didn’t fit well (they were and they didn’t) it would be less work than shaping a whole fender.
Ultimately, no matter which way you go there will be shaping involved. It just might be easier to keep the work isolated to the light box area rather than fighting the whole fender. |
http://forums.pelicanparts.com/uploa...1709369257.jpg |
Porsche sourced fenders are much better than Dansk. We get them at a discount from our local Porsche dealer ( Delaware Porsche Parts dot com) no sales tax in DE and pickup saves a ton on shipping. If you are within a couple hours, it’s worth the drive. It’s the dealer in Newark Delaware but you have to order through the online site.
Reach out to ST-parts, I got my light boxes from them out of Germany and they were about 400 euros. Best price I could find even with shipping to the USA
I can't find ST Parts, do you have a link? |
There is actually a freight forward company in Newark DE that ships to Norway. I sent a rear quarter panel through them to a customer a couple months ago.
Sent you a PM.
The metal was thin and they required a lot of tinkering to get them to work but they worked and it was much easier than struggling with a whole fender. I believe ST parts supplies a lot of other companies/sellers with the light box frames and going directly to the source cuts the cost down. |
Going from the UK to the US you can probably use any of the major freight forwarders, no way around it, the shipping will be expensive. I've also used Craters and Freighters (US based) for some larger items, and that worked well too. |
Thank you! Expensive, to some degree, I am ok with, these fenders are a rare a 935 motors. :)
Thanks for the PM and info! Yeah, I bolted up one of my original fenders and this suddenly became a no brainer. Everything else about the fit is perfect, so I'll do the lightboxes and that will be that. I'm an idiot for not realizing this before ordering new fenders. Only two bolts and this is the fit... http://forums.pelicanparts.com/uploa...1709727377.jpg http://forums.pelicanparts.com/uploa...1709727377.jpg http://forums.pelicanparts.com/uploa...1709727377.jpg |
<iframe width="560" height="315" src="https://www.youtube.com/embed/djq2ljQxxI0?si=X48X_Dspb-NqPUtl" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe> |
Danks fenders (and obviously many other repro-fenders aswell) need a lot of work to make them fit the car. Glad for you, you had the possibility to go with the original fenders and just add the lightboxes. I‘m convinced that this was a good decision!
Here my „problem-zone“ http://forums.pelicanparts.com/uploa...1710321714.jpg http://forums.pelicanparts.com/uploa...1710321714.jpg |
Good luck with yours! |
Just went through this. I purchased some LWB fenders. After my body guy got into them they were going to require a lot of work. Cheapest bestest option cut the LWB fenders and graft them to the OG fenders. They are barely bolted in this Pic and with a fiberglass hood which will be swapped for a metal.
http://forums.pelicanparts.com/uploa...1710343281.jpg |
http://forums.pelicanparts.com/uploa...1710345872.jpg |
Embarking on same project. I’m having to backdate my ‘70S….it made its way all the way to 993 forward dating over its life. Including a g body latch panel.
Grafting on the light boxes is a seriously challenging job by itself. Best of luck! |
I've started tackling the latch panel replacement job and have been inspired by the posts here. In particular @evan9eleven, thanks for the pictures! Here's part 1 of the video, with the latch panel removal:
https://www.youtube.com/watch?v=_JTfDliIBhE |
Great thread! I;m curious…what color is that car?
