alignment specs
1988 M491 cab. Car was lowered to euro spec and aligned prior to my purchase. It sat for many years and when I got the car I replaced the struts. The car is wearing the rear tires excessively and from my measurements there is too much toe in.
The car is just street driven and stock. I am looking for the alignment specs. Does it matter that its a M491 car? I found Turbo specs, but didnt know if they are different.
I am going to take it to a shop, but wanted to have some specs to go by and give to them.
Thank you.
Old 03-01-2024, 12:01 PM
HarryD's Avatar
I would find a shop that does early (1989 and earlier) 911 alignments and tell them you objective(s).
Locally I use a shop that does 911 race cars and they do an excellent job on my street driven car with occasional HPDE and Autocross use.
They should include a corner balance as our cars are very sensitive to imbalances.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-01-2024, 01:10 PM
After doing some more searching I found some information and did some measuring on the car. It seems the ride height is off. I am going to to take your advice and contact some specialty shops about adjusting height and aligning.
Old 03-01-2024, 05:34 PM
HarryD's Avatar
Where are you located. Some folks here may be able to steer you to a competent shop.
Harry
2020 MB E350 4Matic
Old 03-01-2024, 05:35 PM
I am out in the sticks, but about 1 hour from Greenville, SC. I was looking at Thunder bunny racing and Protech. Both in Greenville, SC
Old 03-01-2024, 05:52 PM
HarryD's Avatar
I would reach out to the nearby PCA Chapter to see who they recommend.
Harry
2020 MB E350 4Matic
Old 03-01-2024, 06:13 PM
I reached out to the local PCA folks and almost everyone recommended Protech in Greer, SC. Worked out great. My car, especially the rear, was way out of spec. It drives fantastic now. I highly recommend Protech.
Old 03-09-2024, 06:48 AM
Schulisco's Avatar
I highly recommend the Porsche tech spec book to source the values and many other things about your car. You can get it from Porsche itself, some are available on the net as well...e.g. https://rb.gy/ruaogu
See also:
https://forums.pelicanparts.com/porsche-911-technical-forum/699778-1985-carrera-factory-alignment-specifications.html
https://forums.pelicanparts.com/porsche-911-technical-forum/1044306-alignment-specs-street-de-911-a.html
They're from older ones, I suppose they don't differ that much.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 03-09-2024, 08:24 AM
