alignment specs street /DE 911
I have a 86 Euro 911 Ive been using for DE [did Barber 2 wks ago] and Ax [yesterday] for the past year more track less street .
currently running 225/45/15 NT01's previously 235 50 15 and 225/50 15 888 's with koni adjustable sports w strutbar 27 solid T/s out back turbo tierods does anyone have a 4 wheel alignment tech sheet /suggestions car hasnt been aligned since I got it .it does weigh 2640 no driver.
Old 11-04-2019, 09:09 AM
Bill Verburg's Avatar
Not sure what you are looking for
here's the specs, You'll want to be somewhere between them, left is stock RoW street and right is full race
Here are a couple of good set up sheets
Bill Verburg
Old 11-04-2019, 04:54 PM
Ray Scruggs Recommendations
His booklet Home Alignment of Porsche 911, 912, 930 & Carrera for Competition or Street provides these recommended settings.
From Toe Adjust Techniquest
I've liked the factory settings with only a change to camber front -0.5° rear -1.5°. This maintains the factory camber difference between the front and rear.
Old 11-04-2019, 06:42 PM
Bill ,Harold that exactly what I was looking for as a friend with a good alignment rack is very competent in doing 4 wheel alignment put has little exp with 911
thanks for the help and reply
Bernard
Old 11-06-2019, 04:35 AM
Jeff Alton's Avatar
Just my 2 cents worth as someone who sets up cars regularly for performance street/DE/AutoX/ Race etc....
Go get a read out done of current specs. Describe the characteristics of the car as best you can at the DE and AutoX. Describe what behavior would like to change, and what you would like to be like. Then we could recommend some setting changes for you.
Every driver had different handling behaviors they like/dislike/scares them. The goal here is to tailor the car (as much as possible) to perform at it's peak while remaining in your comfort level.
Hope that helps.
www.turn3autosport.com
Old 11-07-2019, 07:43 PM
