20E engine into 71 VW pickup clutch interface
So, 71 VW bus transmission with a 69 2.0E engine bolted to it. That part works fine, and the bus trans will hold up if I don't beat it. I've done a few swaps like this in the past, but the interface of the bus throwout bearing to the 69 911 pressure plate diaphram fingers could be better. The bus clutch has curved fingers in the center to relate to the flat surface of the bus throwout bearing. The 69 911 PP fingers are flat. See the pics. The flat outer edge of the bus T/O bearing will likely be the contact area on the 911 plate when the pedal is on the floor. Rather have a fuller contact patch. The 911 T/O bearing is rounded, but no way to attach it to the bus release fork. Somebody probably has the fix. Any suggestions?
Try Patrick motorsports in Phoenix, they may be able to help or point you in the right direction.
They understood my Baybus - 911 conversion. Cheers, Woody |
I've got got a KEP made vw flywheel with a Porsche 2.0 bolt pattern center. Use stock Type 1 p/p and t/o bearing. Is '71 bus is still an upright motor? I had a a '68 2.0 in a 70 bug. this set up worked great.
Sold the bug without the motor then sold motor... still have the flywheel. I'll try to tack a picture tomorrow .
'74 911 3.2 Last edited by gecc; 03-04-2024 at 04:54 PM.. |
Yes, last year of the 1600 motor in a bus. I would be interested in your flywheel. Probably need a beefed pressure plate with the 2.0
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-04-2024 at 06:09 PM.. |
John PM sent
'74 911 3.2 |
Took this off a 2.0l solex motor.
Someone did a great weld job fitting a porsche flywheel center to this what I suspect is a VW flywheel |
Price?
John
KEP, Kennedy Engineered Products , in Ca they are the best, they make the part u want Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
I got one from gecc a while ago. Engine is in and running. One more wouldn't hirt.
I'll post a pic tomorrow.
For the welded flywheel, $100 plus shipping
![]() ![]() ![]() 2.0E with webers, SSIs, Monty. Got the bed sand blasted and primed, new bed sides from Klassic Fab, 6X15 fuchs on Venum 5/8" adapters. Working out the dented lower nose now, then strip the rest and paint. New brakes and shocks. Drives great.
Administrator
Wow! It's looking great too!, The Fuchs are awesome
Just found another rear bumper that's straight. Need to take a couple of inches out at the bottom to clear the muffler. Spending $$ at Wolfsburg West, new rubber all around, seat padding and covers.
Sweet!
I'm not picking my nose..I'm porting my upper intake manifold. |
Carrera Baybus
I am closing in on completing this one. It's been in the family for about 20 years and sitting for about 15. All the body work, mechanical and paint was done by Emory's in McMinnville, OR circa 2008. It currently sits on 225/50/16's - 7x16 fronts + 8x16 rears, real Fuchs (weld ups in the rear) narrowed beam in front, 944 hubs, brakes and more. I just got a Kennedy Engineering stage 2 setup for the transition of the 911 motor to the Baybus trans. The next item is the starter motor. Strong advice indicates that a VW Diesel Rabbit starter motor with adapter will do the trick and spin the 911 motor effortlessly. Then some welding for motor mounts, oil tank, mechanical stuff and some wiring. Also trying to get the dash gauges squared away and a bunch of details. I'm not trying to high jack John Walkers thread. Just another stalled Baybus project being reborn. Cheers ................. |
Fun sleeper project. Keep 'em coming.
The '76 "Pyramid Case" transaxle with strong 4.86 R&P is what you want for this project, John.
Looking for one of those, but not cheap.
Actually '75 is what I meant. The last of the 002's .. but 091 diff can be installed with 091 side adjusters.
