New clutch - jumpy throttle when starting
I just got the clutch replaced (it needed it) in my '89 911.
There is an odd issue, however. When letting the clutch out quickly (for a quicker start) the car gets very jumpy, almost stuttering, before smoothing out and taking off. This is only when letting the clutch out quickly. It happens mostly in first gear, but I have also gotten it to happen once or twice in second, again, when attempting to accelerate quicker and letting the clutch out quickly.
Obviously the clutch was what was replaced, so that's the likely culprit. However, if I didn't know what work was done, I would have guessed a fuel/oxygen issue as it feels more like it not getting a smooth supply.
Any ideas on this magical challenge?
Old 03-20-2024, 10:42 AM
It's a 914 ...
stownsen914's Avatar
Anything different about the new clutch vs. old? I.e. different pressure plate, same style clutch disk, etc.
Old 03-20-2024, 12:56 PM
Did they replace the flywheel along with the clutch assembly? It's part of the clutch assembly. Shudder can happen when a partial job is done, like disc only or using the old flywheel.
206 637 4071
Old 03-20-2024, 03:20 PM
proporsche's Avatar
as John said about the replacement.....
This would help-let`s see your repair order -no names needed...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-21-2024, 02:38 AM
The flywheel was resurfaced and it should be full replacement of OEM clutch kit. I'm attaching the work order that was done.
https://www.dropbox.com/scl/fi/tr709bg8pbz4o1nrzszyw/clutch-work_Redacted.jpg?rlkey=htjae6igo3a7o97g1k5ys3r12&dl=0
1989 911 Carrera
1992 G Wagen 350d
Old 03-21-2024, 05:34 PM
kevbo's Avatar
Had the same issue and it was a bad "new" o2 sensor. put the old crusty one back in and it was fixed.
Kevin
1986 Carrera Targa
Old 03-21-2024, 05:46 PM
I gave up on resurfacing flywheels years ago. New only now. Depending on who does it and how accurate their grinder is, it's hit or miss.
206 637 4071
proporsche's Avatar
i am blown away with the prices? just the guide tube for $150?...basic cost is 50.
Looks like they did not do the update to your cross-shaft for fork,they used the old style bearings?
What is the clutch kit with R/B..anybody knows?
Regular price is $750
the prices are besides the problem point here..
This 911 should have rubber clutch disc , did they used the regular spring disc??....the quality of these sachs kit are lately questionable.The spring disc makes a lot of noise in the car but if it is a crappy made, that could be the problem.
As stownsend914 said above....
one more thing, are the nuts of the trans-to the engine tight?
Ivan
rubber disc
https://www.europaparts.com/media/catalog/product/cache/abf26066ecd46d435ee2486b4a5aee03/9/5/95011601252.jpg
Old 03-22-2024, 12:37 AM
Still here
pmax's Avatar
From our host though it includes the slave cylinder ...
Ivan
rubber disc
Cross shaft ?
Old 03-22-2024, 03:31 PM
proporsche's Avatar
Cross shaft ?
yes ,old style cross shaft
.. they did not update it and used this kind
up date kit is usually done when doing clutch job
https://www.pelicanparts.com/More_Info/101518090.htm?pn=10-1518-090-M157&SVSVSI=911M&DID=3008
Old 03-22-2024, 03:48 PM
Thanks all for the replies. Just wanted to update the post with the final work done which include replacing the temp sensor and oil line.
https://www.dropbox.com/s/nldzght3bpf7n12/Screenshot%202024-03-29%20at%2012.08.27.png?dl=0
https://www.dropbox.com/s/7dl5uupv3ivtnni/Screenshot%202024-03-29%20at%2012.08.37.png?dl=0
Prices are high to me too, and I wish I trusted myself to do the work, but alas I don't have the skill! I price compared a bit with reputable shops and this was inline with others.
So working theories and things to check:
1. Resurfacing flywheel - I haven't heard any issues around about this and shop knows what they are doing, but will still check. Anyone else had issues with this?
2. Bad O2 sensor
3. Ensure rubber clutch disc like original
4. Update cross-shaft instead of standard
5. Check nuts are tight from trans > engine
I will be heading to shop today or Monday so all the ideas/fodder I have is very helpful. Thanks!
1989 911 Carrera
1992 G Wagen 350d
Old 03-29-2024, 12:18 PM
kevbo's Avatar
I'd be remiss if I didn't mention that replacing my 02 sensor didn't fix my surging problem in 1st and 2nd. After I tested and cleaned my idle control valve my cold start and surging went away.
https://www.youtube.com/watch?v=MRZG-s_55CU
Forward to 8:52..
This is an easy thing to test yourself. Franny does a great job of making this stuff easy.
Kevin
1986 Carrera Targa
Old 03-29-2024, 03:19 PM
Still here
pmax's Avatar
What's the breakdown for the labor charge and how many hours does each line item translate to ? I was wondering if you were charged the book or actual time for the engine drop for instance.
Pay special attention to what JW (and Ivan) said prior. Saving the extra $1K or so is understandable but ...
... how are you able to check unless you remove the flywheel and have it independently measured ? I think that's the risk tradeoff here. Given what they experienced, I'll wager that one is better off reusing the flywheel as is, in other words vs one with a possibly botched resurfacing job because the latter means the flywheel is likely toast whereas the former means it is at worst the same as before.
Old 03-29-2024, 04:14 PM
Forward to 8:52..
In the video, this is if idle is surging so to me it doesn't seem like this is the issue as the surging ONLY happens when releasing the clutch quickly. That's my hunch, but feel free to disagree.
1989 911 Carrera
1992 G Wagen 350d
Old 03-31-2024, 10:10 AM
I will definitely investigate this as primary culprit, thanks!
1989 911 Carrera
1992 G Wagen 350d
Old 03-31-2024, 10:12 AM
kevbo's Avatar
I hear ya. I relate this to going to the doctor with a symptom and with a hunch as to what the issue is only to find out it was something else. My flywheel was resurfaced too, new fuel lines, new vacuum lines, new plugs, new gaskets and spacers on the manifold, etc etc. For some reason that idle control valve not functioning properly caused surging in 1st and 2nd under load.
I removed that valve, cleaned it tested it reinstalled it. Boom.
I’m learning too. These machines are engineering puzzles - great hobby
Old 03-31-2024, 01:57 PM
The clutch shudder issue became an enging surge issue somehow. Which is it?
206 637 4071
Old 03-31-2024, 02:00 PM
Ha, yes! OK, that's more clear, thanks for that.
Yeah, the odd thing is it's just when the revs drop a bit low and letting the clutch out quickly. If I do a little throttle blip to start and match revs a bit, it's clean.
1989 911 Carrera
1992 G Wagen 350d
Old 03-31-2024, 09:38 PM
Hey all, looks like IT'S SOLVED!
Turns out that it was just a loose 4 pin connector to the fuel pump. We were able to replicate the problem, tighten the connector and all is running smooth as butter.
I'm grateful for all the helpful ideas here and thankful it was something so simple (and not a botched resurfacing).
1989 911 Carrera
1992 G Wagen 350d
Old 04-03-2024, 03:49 PM
kevbo's Avatar
Awesome! Congrats.
Old 04-03-2024, 04:47 PM
