915 trans
It's only working to shift into 1st and 2nd gear, nothing else. I replaced the common bushings for the shift coupling rod and lever, correctly adjusted them, but the shifting mechanism won't move side to side in neutral. I decided to disconnect the linkage and isolate the shift rod going into the transmission, but it won't rotate at all for gears 1/2 to 3/4 and 5/reverse side to side in neutral. I'm looking for any feedback from those who have had a similar experience or experts. Thanks!
If you can’t move selector to select 3+ then the transmission needs to come out and go to a shop.
gearhead
Not necessarily. The next step is to pull the cover plate off the bottom and see if the selecter guide fork the main shift rod runs through has either come loose or has broken tines on it.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I pulled off the cover plate from the bottom, and the shift fork appears intact. I also manually moved both of shift shafts (internal transmissions) into 1 and 2 gear as well as 3 and 4 gear with a pry bar. However, the shifting rod won't move at all into the 3/4 gate. I've attached a movie here (realized its too large memory couldn't upload here). Maybe something is jammed or blocking it?
915 transaxle repair
Does anyone know who does 915 transaxle repair in Austin, tx local or surrounding town? Recommend list based only on who had experience with their gearbox service. Either shop or garage on the side. Thanks
sounds like you have the adjustment out of sync.
lever to the left , 1-2 line , then grab the shift couple , rotate clockwise to max . tighten clamp Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
gearhead
There are other shops in Austin and the surrounding area.
Ass-engine Nazi slot car -- PJ O'Rourke |
I've seen the symptoms you describe arise when the tapered set screw on the coupler becomes loose.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
