Motor Mount Console Carrier - broken tabs - need pics of how it is supposed to look
Edit: I have a 1984 Targa
I'm not entirely sure what this thing is called. 'Engine Bracket' 'Motor Mount Console' or?
In any case, the tabs that bolt to the front engine tin have broken off, see the picture below.
Can someone post a few pictures of how these tabs are oriented on the engine bracket? And, in particular, some close ups of the left and right as they are bolted on to the engine tin, so that I can see how they are oriented?
I'm going to have new tabs welded on, and I need some good pictures of what they are supposed to look like and how they fit with the engine tin.
Thanks!!!
Old 02-10-2024, 04:57 PM
dlagerstrom's Avatar
Not sure if this helps. Looks a little different. This is from 82 SC. What year is yours?
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 02-11-2024, 04:51 AM
As Dave has shown, you have yours upside down. The extra bracket over the mount is to hold the exhaust. You can't see the engine tin mounts on my 1975 - neither on Dave's.
If you have a magnesium block, make sure you check the threads in the block for this rear engine mount, as this is a known weak point for these.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 02-11-2024, 06:36 AM
Registered Minimalist
75 911s's Avatar
If you can mock it up on the engine with the tin you can tell exactly where they should be mounted. You may even see a bead left from where it was mounted before.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-11-2024, 06:49 AM
I was thinking about going through the parts PDF....that image is just what I needed, thanks!
Old 02-11-2024, 08:11 AM
Bill Verburg's Avatar
Thanks!!!
Bill Verburg
Old 02-11-2024, 09:19 AM
Why not just weld the original tabs back in place? A few spot welds and you're good.
206 637 4071
Old 02-11-2024, 10:52 AM
It is not super obvious where they originally mounted.
If you can mock it up on the engine with the tin you can tell exactly where they should be mounted...
Great idea, that is exactly what I will do.
I'll mount the console and front tin and then screw the tabs in where they go. Then my welder can get it right.
Originally Posted by Bill Verburg View Post
...pictures that I needed...
Bill, those pictures are just what I needed to see how they mounted front and back.
Thanks everyone!!
Old 02-11-2024, 03:03 PM
I mocked up all the parts on the engine and had my brother in law weld up the tabs.
I then sent it off for powder coating and it came out great.
Thanks for the suggestions!
Old 04-19-2024, 07:52 AM
