I cant see it in this pic, so thinking internal?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
here you have it, the front of the shift tower
https://i.ebayimg.com/images/g/crIAAOSwMb9ivI4G/s-l500.jpg https://i.ebayimg.com/images/g/qoQAAOSw-xBivI4L/s-l1600.jpg
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
OK, so before I go ripping into this adjustment I am trying to understand what is going on here. Did a lot of searching and have found no reference to adjusting this bit - ie how to set it correctly.
What I did find is this - posted by JW. This seems to nail the problem, and seems to fit with the above post by Schilisco (Thomas - I may have misunderstood you). "if the stick is not all the way over and up into 5th, the little flipper that keeps you from shifting into reverse and allows you to go 5th to 4th properly, can actually hang up and jamb the stick from coming out of 5th. the stick needs to completely clear the flipper into 5th." Is this adjustment related to the above description? I also found several references where as Ivan stated - make sure you shift out of 5th above 60mph. It seems not uncommon, but a weird characteristic. Alan
last time if i remember correctly, to play with the 2, was for the stick to be too loose..side to side...
Ivan
What I did find later was that this adjustment was added post'77. My wsm goes to '85/86 and does not mention this.
But I did find a line in a thread that said it was an adjustment for the shifter 'basket' and that it was to be tightened so no play. Just not quite clear what I am doing if I tweek this. Flying blind - since I have not had to pull the linkage or gbox apart on this car, my wsm doesn't cover this, and all is good, except.. I did find a thread with another SC with exact same issue. But like many threads, it was like reading a gripping novel, with the last page missing. Regards Alan
