gearbox shifter query
So my SC gearbox works well - no issues over the last 20 yrs. Even after 1-200 miles without a clutch once. But it does have a quirk which I don't understand.
If I coast to a stop in 5th, I cannot get it out of gear. So I work around that by downshifting to another gear. Then it is fine at a stop, can get to neutral no problem. But if I arrive at a red light for example, in 5th, I would be stuck in 5th. If I tried to deselect by force it feels like it would break a selector fork. I have managed to get it back to neutral by rocking the load on the box with some revs and the clutch. Pick the point when the load just shifts from load-no load. What causes this issue? Not about to tear the box apart, it is fine. But would like to understand what is going on. Thanks Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
very strange to arrive to stop sign in 5th if you ask me;-)
i`d just say, don`t do it... Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 04-27-2024 at 10:25 AM.. |
My first thought is to check or just replace the shifter bushings and then readjust the shift coupler. There are plenty of videos on how to do this, just search.
Be sure to replace all four bushings; two in the coupler itself, one on the shift rod and one that connects the shift lever to the shift rod. Our host sells a kit with all the bushings needed: https://www.pelicanparts.com/More_Info/PELBUSHKIT1N.htm?pn=PEL-BUSHKIT1N&bc=c&SVSVSI=0581 This is a relatively easy Saturday afternoon DIY. Last edited by ErrorMargin; 04-27-2024 at 03:16 PM.. |
Yeah I guess that is a possibility. Easy to do. Thx
"very strange to arrive to stop sign in 5th if you ask me;-) i`d just say, don`t do it..." Just coasting - clutch in, knowing I am going to a full stop. Why go thru needless downshifts? What I tend to do then - knowing the issue, is flick to neutral and just coast. Alan
PCA Member since 1988
I assume you made damn sure the clutch is fully disengaging.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Inherent in the design of any standard-shift car, is an expected, down shift - a few gears - if you are anticipating a stop, it's much safer and healthier for the mechanics of the clutch & transmission than what you are practicing. The fact you can't shift out of fifth, is proof that the Porsche engineers are mad at you. Your car has a soul you know, don't hurt its feelings.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
Yes - I guess they are punishing me. One downshift is enough to rectify it. So I don't coast to a stop in 5th - for many yrs. because I know what happens.
The odd thing is if I do same in say 2-3-or 4, no issue. Just 5th. Yes Pete, clutch is good. The gearbox and clutch are working beautifully (fitted complete new clutch asseembly 2-3 yrs ago)- can't complain. Just wondering what the issue may be - other than some angry guys in Stuttgart. I think the F1 engines have telemetry that tells the builder on the other side of the world every time is is fired up. Maybe my SC is ahead of them. Some day, sometime, I may end up pulling the gbox down. If so, if there was something in there that was not right, I would prefer to be able to address it. Regards Alan
i wonder in what speed you are at in 5th when you are cruising???
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Open hwy - say 100kmph (about 60 mph).
the typical situation would be like a country road, approaching a stop sign. 100m out, start slowing, braking, knowing you have to come to a full stop. Not a lot to gain by downshifting thru 4 or 5 gears. For what reason? Coast to a stop and look for neutral. If your were in 5th you would be stuck in 5th. Not sure if it is a general problem, or an issue in the g/box. A first world problem, for sure. Just wondering if there is a problem in the gbox that could be rectified at some later time - something not quite right. Alan
kinda slow for the 5th gear i would say 100m to go and still in 5th??.....basically shift into 4th and problem solved....
Ivan
That's definitely a weird problem.
If you shut the engine off does it does it allow you to move from 5th to N? If you were already stopped and in N, then put it into 5th would it immediately stick, or could you just move back to N? is it associated with coasting to a stop in 5th, or just being stationary in 5th? |
let`s see what Matt Monson will say....
Ivan
if the adjusting nut (22mm I believe) on the front of the shift tower is too tight, you can get stuck in 5th due to the lockout mechanism. Ask me how I know...easy to check it.
If I am coasting to a stop, in 5th I have to get it out of 5th before stopping, or it will be stuck there. Sounds like The torch has supplied an answer - thx. Just didn't know where to look. Where do I find that nut? Alan
Some of our roads are now reduced to 80kph (50mph). Why, because people keep crashing. So instead of improving the roads, or making people drive better, it is better we all go slower. Luckily I get to drive my 930 at WOT on a track, so I am happy cruising in my lazy SC. The torque makes for very easy driving, and I am still allowed to attack the corners at a speed the car will handle :-) I have had 2 clutch cable failures (clevis pin/fork). No fun. Have modified that bit now. So I just don't do needless downshifts when cruising to a stop. But yes - down 1 gear and problem solved. But my original Q was - what would cause the issue. Looks like The torch has the answer - which I am glad to find. Regards Alan
Before you try to pull the gear lever out of the 5th gear, push it more into the 5th gear lane. Then try to pull it into neutral lane. Does this work?
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Thanks Thomas - but I am not really looking for a work-around - I just avoid the issue. Was really looking for the reason it behaved like that.
Regards Alan
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 04-30-2024 at 01:00 PM.. |
Ivan
I am not sure where it is Ivan. I did post a query for Thetorch - but not heard yet.
I am guessing it is external near the shift stick, rather than internal in the box? Regards Alan
