GettinHeadStuds's Avatar
993 gurus...
ATTN: Max, Leland, Richard L, other 993 owners
Were there any significant differences in the '97-'98 993s when compared to the other 993s?
Any mechanical weaknesses I should keep in mind when looking at the '97-'98 TTs, c2s, c4s? i.e. valve guides?
I'm at work and have no access to my bible... i mean porsche information book.
p.s. I ran a search, but couldn't find a thread with the information i needed in one place.
83 SC (gone) / 72 T (gone)
Old 10-20-2004, 09:20 AM
maxnine11's Avatar
the main difference during the 993 production run was the varioram intake system introduced on the '96s. ( a little more HP and a fatter torque curve)
the '95s had an engine wiring harness problem that is now a recall and a free fix.
the valve guide wear problem is hit or miss. a lot of people are approaching 100k miles without a problem, others have had to do their heads at 50k miles.
blocked secondary air injection ports can affect all model years, but can cause more grief (aka CEL) with the '96 and up OBD II cars. If the ports aren't completely blocked, there are now DIY write-ups on flushing the system out to clean up the carbon build-up to hopefully fend off the dreaded CEL. If the car suffers from high oil consumption due to excessive valve guide wear, and that is the source of the carbon build up- obviously a valve job is the only real cure
'95 cars are easier and cheaper to chip, '96 the hardest and most expensive.
The AWD system seems to be fairly trouble free. But, it is obviously something else that can go wrong on the car, and i don't think any of the components are cheap. where you live and the road conditions you drive in will help you make the 2wd vs. 4wd choice.
The TTs AFAIK are the same for '96 and '97, other than the aforementioned chip diffrence. I think the only Turbos made in '98 were the $$ Turbo S models.
Basically, there isn't a really good reason to choose one particular model year over another; spend your time being choosey when it comes to the condition and maintenance record of the cars you're looking at. And the usual advise- Get a PPI !
The first US 993s are now ten years old!
max
max
Old 10-20-2004, 09:41 AM
Very good, thank you Max.
Old 10-20-2004, 11:04 AM
Rick Lee's Avatar
To all prospective 993 buyers....long
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-20-2004, 11:15 AM
Ok, now that thread is exactly what I was looking for. Thank you much.
Old 10-20-2004, 11:24 AM
Bill Verburg's Avatar
Max and Rick summed it up relly nicely. I would add my 2cents.
The change from OBD1 in '95 and on all ROW 993s to OBD2 usen only on US and Canada '96 on 993 was the bifggest thing that will affect you as an owner. Particularly where emissions inspections are in effect.
Bill Verburg
Old 10-20-2004, 12:23 PM
Rennlist? Wtf is that?
I'll give it a looksie, thanks.
Old 10-20-2004, 03:31 PM
Member w/ Title Problems
Jason Porter's Avatar
I work at Otto's Venice, and we have found a solution to the secondary air injection problem, that works 95% of the time, and costs around $1000.00 US. There's actually a write-up on it in the June(?) 2005 Excellence in the tech section.
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 07-12-2005, 09:32 PM
