Does the 964 motor really need it’s crank damper?
I have a 964 3.6 in my ‘75. For year I ran the stock crank pulley. It has 3 grooves and is a vibration damper too. These can die over time as the rubber part of the damper degrades. A few year ago I went to a Rothsport crank pulley without a damper. It’s lighter weight, cleaner look, and its new (vs a 31 year old rubber damper).
Is there an issue running the 964 motor without a damper? It;s been a nagging question in the back of my mind, and laying under the car recently I was staring at it thinking hmmm….
I almost went with the Fluiddamper when I changed things up. I love those things from my muscle car days.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-25-2024, 08:41 AM
Bill Verburg's Avatar
I don't know
But every 964 crank factory motor that I have seen, including RSR and Cup has the 3 sheave damper pulley.
I have seen engines where the owner has put a non damper pulley on they claim no issues.
I tend to go w/ the factory
I believe that Neil Harvey developed the ATI Super Dampers for the GT3 crank used in most probably all the late 4.0 air cooled motors
Last I heard He was working on one for the 993, maybe 964 too. He sometimes responds over on the Engine building form so maybe ask there.
the 964, 993 and GT3 all have different snouts so the pulleys and by extension damoers are not interchangeable.
Bill Verburg
Old 05-25-2024, 09:23 AM
Bill, great advice. That looks like the Clewett serpentine conversion as well. Any idea which ATI that is though? They don't list a Porsche as a fitment.
Old 05-26-2024, 08:51 AM
Racer
winders's Avatar
I've seen a zillion non-Factory race engines built on 964 and 993 cases. 3.6L up to 4 Liter....I can't recall one I have seen with an ATI damper ...and an only a few with the Clewett serpentine setup. 90% have an aftermarket pulley setup instead of the Factory 3 groove pulley.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 05-26-2024, 10:37 AM
That engine is a buddies, it is a Gamroth built 4.0 w/ w/all the goodies.
AFAIK you need to buy from Rothsport or Neil Harvey.
Again these currently(to my knowledge, are only available for GT3 cranks
Bill Verburg
Old 05-26-2024, 11:50 AM
Bill, well I know Jeff so I can just give him a call. That motor in your pictures has no disti, runs off a crank trigger, etc. Right now my motor is pretty stock (though Jeff would like to change that for me….and some $$).
Old 05-26-2024, 01:05 PM
PCA Member since 1988
My advice: Do not run without a damper if you want long engine life. For the racers, who will rebuild motors every season (or more often), fine, do whatever makes you fast. For hot rod street cars that won't see 10,000 miles the rest of their lives, do what you want too.
But for street cars that you want to last 100,000 miles or more, there are good engineering reasons engines have harmonic dampers. I'm sure Porsche would not have spent the extra dough to put a damper on the 964 engine if their durability testing didn't justify the expense. Furthermore, if you change to a lightened clutch/flywheel, you better use the damper.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-26-2024, 02:07 PM
Correct, no dizzy, Extreme heads,, the best of the best and all of it
As i said all the 964 crank factory motors use a damper of some sort, either the 964 3 sheave or the later RSR serpentine/
Here's the best pic I could find of the damper used w/ the serpentine, this is a 993Cup engine which uses a 964 crank(they all do), most have the 3 sheave pulley but this one was upgraded to the RSR serpentine setup. the damper pulley part # is 964.102.150.20
Bill Verburg
Old 05-26-2024, 03:19 PM
group911@aol.co's Avatar
Bill. Here is the pulley I came up with for a cup and I don't believe it is dampened.
I'll see if I can find the part number.
Thanks,
Bob
group911@aol.com
Old 05-26-2024, 05:47 PM
I/m sure that there are several different pulleys that enterprising builders have come up w/ but the fact is the 993RSR factory serpentine pulley is is damped, as I stated all the factory motors that use the 964 crank use one form of damped pulley or another.
993Cup which uses the 964 crank used the stock 3 sheave,
Here is the page of the'97 RSR parts book that best illustrates the point
Bill Verburg
Old 05-27-2024, 08:27 AM
Correct on the RSR. Interesting that the damper also had a v-belt groove and your parts list actually shows the v-belt part number. Wonder what that would have driven?
Thanks,
Bob
group911@aol.com
Old 05-27-2024, 09:30 AM
I've seen some running a v-belt
964 RS l/wt
93Cup
993RSR sprint motor
Bill Verburg
Old 05-27-2024, 11:27 AM
I'm a little slow but I think I'm getting it now. The serpentine portion of the balancer goes on after the v belt portion which has all the timing marks on it and is therefore necessary. Sorry I didn't pull the serpentine pulley off of that rsr engine to see how the two halves were mated.
Thanks,
Bob
group911@aol.com
Old 05-27-2024, 11:53 AM
I would agree that it's probably there for a reason. I removed mine (964) when I swapped the motor to an early car in the mid 1990's. It also has a lightweight flywheel and clutch. I removed mine mostly because it was a pain to get to the crank pulley to rotate the motor to adjust the valves. I understand the harmonics could potentially break the crank so proceed at your own risk.
Not to hijack the thread, but on the above posted pictures I note that the heater ducks are mostly vented to the atmospher. I guess it's not critical to have that duct sealed?
Curious.
Tinker
Old 05-27-2024, 04:38 PM
Wow you guys are a wealth of knowledge! So I guess I am going to source a serpentine and that ATI damper....or a fluid damper. Hmmm.......
No I'm not going over 7k RPM, but still.
Old 05-28-2024, 06:15 PM
I called API about getting a damper made for a 964 crank they wanted an order of 10 at $1000.00 each. the one you see in the picture is for a GT3 crank. I run with clewett setup. patrick motorsports make a serpentine belt kit also. https://patrickmotorsports.com/collections/all-products/products/eng96410615180rsrpms The thing that get me with the stock 964 crank pulley is the rubber is only on the ac pulley. not like a true damper. I have one here I took apart.
Old 05-29-2024, 03:10 AM
Clewett wants wants $625 for the non-A/C (out of stock…….and Patrick wants $1700. Wow. I know Rothsport uses them, but dont see it on their site. Might be worth a call. Hmm.
Old 06-03-2024, 11:46 AM
