911SC '82
How to bypass headlights for fog lights
I'm using the fog lights wires to turn on/off my fender oil cooler fan and I'd like to be able to use it without turning the headlights on. not a biggie but while I'm there...
i don't see any jumper visible here on my fuse box but I guess I need to unscrew it and see what;'s behind... must be there right? I don't see any other way it would be...
Do you not have a thermostat for the fan? The fans I bought came with an adjustable thermostat. The thermostat controls a relay that powers the fan. I used a switched power wire and ran a wire with inline fuse to the relay/fan.
Find Spoke's LED Products: www.spokeworksled.com |
Check posts 4, 5, 8, etc, here...
Manual control of 3.2 oil cooler fan via existing fog light circuit / dash switch ...they describe the fusebox grey wire relocation procedure for independent foglight circuit control.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Here's the kit I purchased to control the oil cooler fan. Includes everything needed to connect the fan to the battery POS terminal.
https://www.americanvolt.com/products/automotive-electric-engine-fan-adjustable-dial-32f-248f-thermostat-relay-complete-wiring-switch-kit
PCA Member since 1988
Francesco: Replace your damn fuses! Do you see how many of them are distorted? That's from many heat cycles over years. You WILL have miscellaneous electrical gremlins if you don't.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
911SC '82
I bought the harness with a relay that connects to a temp switch, but I didn't see anyswitch. that would be ideal, but today I tested the manual mode and I'm pretty happy with it
911SC '82
I think I have some spare thanks for pointing that out! (not super easy to find them online) |
911SC '82
was it easy to install? |
The probe fit right between the fins on the oil cooler and works well. Where the OEM oil temp would have a plateau when the oil cooler diverter opens up in cooler weather, in hotter weather the oil temp would rise above that plateau. With the adjustable thermostat controlled fan, you can set a higher plateau and see it on the oil temp gauge. Here's some info on my install: Oil Cooler Fan Kit for '86 930
911SC '82
just ordered, thanks! |
911SC '82
https://www.amazon.com/gp/product/B09N3HJP9C/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 installed it today and works like a charm. my oil temp now never goes past 9 o'clock even in hot day and heavy traffic... in my case I zip-tied the probe to the IN oil line to the radiator, then I drove around the hood until the oil gauge was barely past 9oclock, and then I set the temp of the thermostats inside my frunk. i love that I also have the fog light switch inside the cabin as a kill switch (I removed my fog lights and old valance so I'm good!) thanks again for the tip |
