Still here
pmax's Avatar
Originally Posted by AndrewCologne View Post
Completely normal sounding? Really ... to me it sounds totally uneasy and never meant to be like that per factory default, and this also is proven by the first video where you can see in the plot that something in the electronics is flawed.
Yep, not normal.
OP,
Open it up and have a look see.
It's all analog components in there anyway. Might be something obvious.
Old 06-02-2024, 12:28 PM
PCA Member since 1988
The other guys have covered most of the bases. However, don't overlook the frequency valve itself. It may be dirty or sticking. I would put a bottle of Chevron Techron Concentrate in the tank, go drive the snot out of it for a week or so, then see if the idle stabilizes. If not, then remove and inspect the FV. Since it works like a fuel injector, you can have it cleaned by a shop that cleans fuel injectors.
My experience with old electronic components (as well as new ones) is that they tend to either work, or not. Sometimes they are intermittent (the worst kind). Check and clean electrical connections too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-02-2024, 03:08 PM
Yes, that's case for components, but not for the circuit boards they're mount on.
Dave
Old 06-02-2024, 04:55 PM
AndrewCologne's Avatar
Originally Posted by booyah911 View Post
O2 sensor is brand new. Had the same symptoms with the old one too.
It sounds like the lambda computer may be the culprit. Any suggestions for repair? I see the specialized ECU folks fix these and the feedback on the forum is mostly positive. Alternatively, anyone have a known good one they want to sell?
First check the link Dave mentioned – fast easy and very close to your location as also based in CA IIRC.
And if maybe finally after checking the ECU it shows that a bigger repair is not worth it, have a look here.
https://nineelevenheaven.wordpress.com/the-911-sc-3-0-engine-with-catalyst-and-lambda-control/
https://nineelevenheaven.wordpress.com/the-lambda-control-of-the-911-sc/
https://nineelevenheaven.wordpress.com/optimized-control-unit-ecu-for-the-911-sc-with-lambda-control/
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 06-03-2024, 12:49 AM
Thanks for the help, everyone. Andrew, your website is great.
Here is a photo of the lambda computer. Nothing sticks out to me.
I'll check out the website above, but first I'm going to double-check the relay is functioning properly. I verified it is getting 12V at terminals 88 and 30 while running, but it occurs to me that I didn't check whether the switched power at terminal 87 or 87B remains hot. I'll report back tonight.
Old 06-03-2024, 05:54 AM
The typical circuit board problems occur on the bottom, where the circuit tracks are, and intermittencies occur.
The worst case problem occurs when the hybrid circuit fails, as there's no replacement.
Dave
Old 06-03-2024, 06:39 AM
I hate those hybrid circuits and it seems they are almost everywhere in our cars. The heater blower relay and the newest version of heater automatic control are partly built with such hybrid cards and that makes them very hard to hack.
Gilles
RoW 88 Carrera coupé
Old 06-03-2024, 07:32 AM
Good to know.
Confirmed that the relay is working perfectly fine. I will send out the ECU for testing/repair.
Old 06-03-2024, 08:40 AM
Closing out this thread, I sent out the lambda computer to Loren at systemsc and it turned out to be in good working order. The signal to the frequency valve was as expected and there were no other issues. Loren resoldered some connections anyway and took the time to discuss the issues I thought I was having. I highly recommend Loren's services. After some discussion, I updated my scope settings and fine-tuned the mixture screw to get the following at the test port:
https://www.youtube.com/watch?v=nZf-Si8OtXY
Loren confirmed some idle fluctuation is normal, and it looks like the duty cycle fluctuations are not as extreme. From here, Loren suggested I also confirm the following, which I will do soon:
1. monitor the cold start enrichment duty cycle (~ 70%), a ground (ECU pin 7) from the temp switch on the chain cover right bank
2. check the acceleration enrichment switch ECU pins 12 & 14, from the relay next to the ECU, as the acceleration pedal reaches about 1/2 way full throttle
Otherwise, she's up and running!
Old 06-24-2024, 08:32 AM
Still here
pmax's Avatar
Do I just need to fiddle with the mixture adjustment more and it will even out? It seems like the system is fighting to try to get to lambda 1.
Yep, you nailed it right at the beginning.
In hindsight, the duty cycle oscillation between 60 and 45 should have informed us right off the bat.
Old 06-24-2024, 06:53 PM
Originally Posted by mysocal911 View Post
Dave,
Do you have a financial interest in this company?
Rutager West
Old 06-24-2024, 07:45 PM
Originally Posted by rwest View Post
Dave,
Heard about this company from the many Porsche dealers and independents they provide products and support for here in SoCal.
They support early 911s thru 906s, 959s, 993s, to the Porsche Cayenne. Surprised you haven't heard about them. Give them a call sometime.
Dave
Old 06-24-2024, 10:12 PM
