MFI question
Hello everybody,
Iīm working at a friends car right now. Itīs a 2.4 MFI. The car has been sitting for quite a while and everybody who was working on it messed up the setup eben more. Now that we got in running, adjusted the butterflies and all rods itīs running quite good. We took it on the street with an AFR meter in the exhaust and found out it gets extremely lean as soon as we pushed the throttle down even a little bit. Now we just found out the that lever at the mfi pump has no function. I can push it in all the way and nothing changes. Neither rpmīs, nor the AFR. Could it just be disconnect inside the pump? If so which cover do we need to take off? Also we noticed that during the process of adjusting everything, cylinder 1 injector gets less and less fuel from the mfi pump (itīs not the injector). Is there something like a filter on top of the pump under where the fuel lines are mounted? Many thanks in advance, Malte |
you may get more information over on the Early S Registry.
ptrsbtrs
In case you haven't already, get a copy of the CMA manual :
Check Measure Adjust. Invaluable info to help sort out the MFI. And, as KR said, go to Early S registry. Not to mention the Univ. of Youtube.. Good Luck! |
No reverse gear in life
David Alstadter - There is no reverse gear in life!!! 74 911 2.7 Carrera 9114400120 - licht grün 71 911T 9111121235 - recreated as 2.8 RSR glasur blau (3.0 MFI) 73 911S 9113301270 - silber metallic (sold) 72 911T - bahia rot (2.8 RSR) SCCA ITGT 95 LA & SD champ (sold) |
It's a 914 ...
It is possible for the rack inside the pump (or other components for that matter) to freeze up from being gunked up or corroded. You can pull the side or end covers off the pump to examine them and see what may be stuck. Best off the engine of course, and remember to drain the oil from the pump first.
(man/dude)
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Thank you everyone!
