Safari alignment specs...any suggestions?
Hey everyone,
I've been working on a safari conversion for a 78 SC RoW for the past few months. Pulled the engine to repair some oil leaks, new fuel lines, and other repair work and ended up installing an elephant racing kit, with braid 16" wheels and BFG K02 tires. It's been a lot of learning but a lot of fun. This car will hit some dirt and gravel roads but will mostly driven on pavement.
I've corner balanced the car and am now trying to determine the 'best' alignment specs to give to my mechanic. Using some string and a digital level I was able to get the car straight enough to drive 45 miles from my garage to home but plan on bringing it into my Porsche mechanic next week to dial it in (it's currently not quite straight).
For the purposes of getting it home I went with specs below...
F: Camber = 1.5 degree neg.
F: Toe = 1/16" out
F: Caster = Did not set
R: Camber = 0 degree (could not get any neg camber)
R: Toe = 1/16" in
Looking for any guidance and advice, would appreciate any help or ideas. Pics of the car below, thanks.
1978 - Safari
1979 - 911SC Coupe
1983 - 911SC Coupe
1984 - Carrera Targa
Old 06-05-2024, 05:55 AM
If it's mostly a street car I would think relatively stock alignment numbers would work. I am just guess, but I would think that would help minimize tire wear, etc.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 06-06-2024, 08:19 AM
tailwind22's Avatar
If you haven't already, I'd reach out to Chuck at Elephant Racing. He was a great help to me on my safari build.
73 914-6 GT tribute, 2.7L twin plug
23 911 w/aero kit
07 GT3 RS Pumpkin
Old 06-07-2024, 06:40 AM
PCA Member since 1988
Toe out on your front or rear wheels will make it twitchy. I don't see any reason to deviate from the stock alignment specs if it's driven mostly on the street.
How high above the Porsche F/R ride height specs did you raise it?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-07-2024, 06:00 PM
Been meaning to post an update, it dawned on me to just call Elephant, Chuck was a big help and gave a recommendation. Car is going to the mechanic on Monday to get aligned.
My final height was about 29.5” front, 29” rear. Weight 40/60.
1978 - Safari
1979 - 911SC Coupe
1983 - 911SC Coupe
Old 06-07-2024, 07:40 PM
drola's Avatar
I've built a couple 911SC safaris and always align them to stock specs.
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
2014 Ram 2500 Cummins
Old 06-08-2024, 05:21 AM
Cory M's Avatar
I agree with stock specs. I run mine lower than Chuck's recommendations, more like 27.5" because I like the rally style more than monster truck. Front is easy to adjust, I had camber plates already. Rear is more difficult to adjust so you don't have positive camber.
Old 06-08-2024, 03:26 PM
