blau bamburg radio connection questions
getting everything ready for install and realized im not 100% sure of a three terminals and have not found a good scematic yet, is there anyone that knows from experience what these two holes and small spade connector are for?
Old 06-05-2024, 03:42 PM
stevie 77 930's Avatar
The spade connector you have "?" is the power on switch to a power antenna
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 06-05-2024, 05:52 PM
ok, so its elec antenna motor red/positive, excellent . i cant imagine what the other two 2.6 mm pin connector holes are for. but probably wont matter. thnx stevie
Old 06-05-2024, 06:32 PM
Electric antennas, require a constant "hot" from a source and this switched hot to power up the antenna. When the radio is turned off this connection is turned off this triggers the antenna to retract
1983 911SC
2018 GTS
2023 Audi A4
Old 06-06-2024, 07:54 AM
antenna has a red blk grn, guessing that the red is constant 12v +, so it might be switched on ground circuit blk or green , i ll look at bentley for antenna diagram, of course the new anntena had no diagram. thnx again stevie
Old 06-06-2024, 11:54 AM
