Help Identify this Tach 10K 4 cylinder ...
I have a strange tachometer in my possession...You have to love swap meets!
112 mm diameter 10K rpm silver button date code 3.67 4zyl.4Takt 230/3/2 stamped 12v/14000Imp with the 14 over stamped with 20 so 12v/20000Imp date stamped 3.67 and blue ink stamped 225 4 67 Face plate part number 901 741 302 06 its been opened. flat screws show wear So, what's the deal with a March 1967 10k tach for a 4 cylinder ( or maybe an 8 with twin plug? ) Thanks, Scott ![]() ![]() ![]() ![]() ![]() ![]()
Flat Six
Cool tach; no help from me but thanks for sending me down a 10k rabbit hole!
Found this, you might be interested: https://www.early911sregistry.org/forums/showthread.php?75266-10-000-rpm-porsche-tachometer-can-anyone-help
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
I spent a weekend down that hole! nothing definitive yet.
gearhead
It’s been redone. Not original.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Matt is correct! I've seen many like this and have built many myself. Your tach started life as a standard 67/68 912 tachometer. The factory 10K faces were available from Porsche until about 10 years ago so many were installed on these 10K tach conversions.
The 20 was stamped over the 14 when the conversion was done to signify that it was converted to 10,000 RPM for a 4-cyl engine. The original 14000IMP signifies 7,000RPM 4-cyl. If it were setup for a 6-cyl the impedance would be 30000
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Coram Deo
Love this place.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
