!978SC No crank, No juice, Need advice please
My car has been starting right up and running well all summer. Yesterday when I tried to start it I got nothing...
When I insert and remove the key I feel/hear the click. When I turn the key a bit (to the first position) the instrument cluster dies not "light" and leaving it in that position the fuel pump relay does not whine. I also cannot roll up the windows, turn on the radio, etc. It's as if the key was not in the ignition.
Turning the key the rest of the way I feel the spring pressure on the key but the starter does not engage.
Battery is 12.2 volts. The horn and flashers work with or without the key in the ignition. I checked all the fuses and removed/reinserted the black and red relays.
This happened right after I washed off the car. Used very little water as I have the targa top off. I can't believe it is related, but the timing is suspect.
Does this sound like the ignition switch went bad? Is my next step to check voltage/continuity from the battery to the ignition switch and light switch?
Thank for your opinions and advice!!
1978 911 SC Targa
2007 Boxster (sold)
Old 07-14-2024, 07:44 AM
It sounds like a bad ignition switch (the electrical portion). There is no fuse between the battery and the ignition switch for the starting circuit so ... nothing to check.
Crawl under the car, put a DVM on the starter solenoid, get back out from under the car, turn the key over to see if 12V is seen at the solenoid.
IF yes, starter is bad,
IF no, ignition switch is bad.
Be damn sure you are NOT under the car when the key is turned during the test.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-14-2024, 08:34 AM
Thank you yelcab 1. So this morning it fired right up as I was going to check the ignition switch.
So perhaps I did get water somewhere yesterday. Where might the water have gone to cause the issue described in the first post?
1978 911 SC Targa
2007 Boxster (sold)
Old 07-14-2024, 12:24 PM
Still here
pmax's Avatar
I would do more of this before mucking with the ignition switch.
Remove the fuses, get the tips and contact points at the box nice and shiny.
Old 07-14-2024, 12:50 PM
PCA Member since 1988
If you had a bad ignition switch, it would most likely have given you warning for some days or weeks before this, sometimes working and sometimes not. If you can jiggle the key and it lights up, then it's the switch.
The symptoms instead indicate a high resistance connection to the battery cables or the ground strap. Remove the cables from the battery terminals, wire brush the terminals and clamps (there's a round wire brush for this purpose) or use sandpaper, then grease and reconnect. Same with the battery ground cable or strap. It will probably fire up. Then for good measure, remove and clean the ground strap from the transmission to the body under the car.
Report back here your results.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-14-2024, 02:23 PM
12.2 isa little low for a resting battery, if its under warrantee i would have it checked while you have it out cleaning grounds.
Old 07-15-2024, 06:34 AM
Gotta love that 911obgyn user name! If you're from around here the Eugene part makes it make sense. Kudos.
Old 07-15-2024, 07:14 AM
theiceman's Avatar
tighten the battery posts
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-15-2024, 07:30 AM
Thank you all for your helpful advice! The car has started up just fine over multiple attempts in the past two days. So it appears that something got wet while washing and took a day to dry out.
I am still taking everyone's advice and cleaning/tightening fuses, relays, ground straps, battery terminals, etc. I see this as proper preventative maintenance even if it was not directly related to my most recent issue.
1978 911 SC Targa
2007 Boxster (sold)
Old 07-16-2024, 06:59 AM
