Russ1302's Avatar
901 Rebuild questions.
I have an earle 901 5-speed, that I'm rebuilding. The main gear select rod that runs tru the nose cone has alot of groove in the end of it. They runn linear with the shaft, and are on the end that goes into the transaxle case. Is the common? What is the fix for this? It seems odd to have all of the wear on the steel rod when it seats in aluminum. Any input would be a big healp. PS I'm using a different case, due to all of the wear.
Russ
Old 06-26-2003, 11:57 AM
Russ1302's Avatar
Bump!
Old 07-01-2003, 10:22 AM
canna change law physics
red-beard's Avatar
You might have some steel chips in the transmission and one or more of them have become lodged in the shaft area.
Also, the shaft seal, the original one on most of the 901s, is partially made of steel. All of the replacements are plastic. It could be damaged. Is it leaking around the seal at all?
James
James
Red-beard for President, 2020
Old 07-01-2003, 12:08 PM
