-   -   window regulator pivot pin question (http://forums.pelicanparts.com/porsche-911-technical-forum/1165110-window-regulator-pivot-pin-question.html)
sb66 08-01-2024 01:42 PM
hello everyone
I have a 1984 911 carrera conv. that i need a window pivot pin for. I noticed there are 2 sizes 23 and 26mm - i am not sure what size I should order as mine is sheared a couple of mm away from the slotted head. i have seen several articles on here but I must be missing this detail for some reason (blind perhaps) -
any help would be greatly appreciated
thanks
sean
Dpmulvan 08-02-2024 06:03 AM
If I remember correctly the pin that usually breaks (outside of the coil) isn’t available. The pivot pin they sell is for the inside of the coil spring. It’s been awhile but I’m pretty sure you have to make your own.
sb66 08-02-2024 07:04 AM
oh great - - -thanks i will do a search to see if there are tips on what to use for that- do not want to have to tear the doo apart for a repeat if I can help it
thanks again
WMichelsen 08-02-2024 09:00 AM
As Dpmulvan suggested, are you referring to the main pivot pin? Or the outer tension pin?
Here's a starting point for you:
https://forums.pelicanparts.com/porsche-911-technical-forum/1153558-window-regulator-pins-87-a.html
MBAtarga 08-02-2024 12:32 PM
There are several threads showing fixes including using a modified shoulder bolt. Search and you'll get some ideas.
sb66 08-02-2024 02:26 PM
that will work - awesome - thanks!
sb66 08-02-2024 02:27 PM
thanks everyone - super helpful! - off to the garage!! - get this together and back on the road!
sb66 08-07-2024 04:39 PM
just wanted to say thanks again for the help really appreciate it - bugger of a job - stainless nuts and bolt worked great as per the recommendations - all back together- time plus $5 in parts
