window regulator pivot pin question
hello everyone
I have a 1984 911 carrera conv. that i need a window pivot pin for. I noticed there are 2 sizes 23 and 26mm - i am not sure what size I should order as mine is sheared a couple of mm away from the slotted head. i have seen several articles on here but I must be missing this detail for some reason (blind perhaps) -
any help would be greatly appreciated
thanks
sean
Old 08-01-2024, 01:42 PM
If I remember correctly the pin that usually breaks (outside of the coil) isn’t available. The pivot pin they sell is for the inside of the coil spring. It’s been awhile but I’m pretty sure you have to make your own.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 08-02-2024, 06:03 AM
oh great - - -thanks i will do a search to see if there are tips on what to use for that- do not want to have to tear the doo apart for a repeat if I can help it
thanks again
Old 08-02-2024, 07:04 AM
'87 Targa
As Dpmulvan suggested, are you referring to the main pivot pin? Or the outer tension pin?
Here's a starting point for you:
https://forums.pelicanparts.com/porsche-911-technical-forum/1153558-window-regulator-pins-87-a.html
Old 08-02-2024, 09:00 AM
MBAtarga's Avatar
There are several threads showing fixes including using a modified shoulder bolt. Search and you'll get some ideas.
Mark
'83 SC Targa - since 5/5/2001
Old 08-02-2024, 12:32 PM
that will work - awesome - thanks!
Old 08-02-2024, 02:26 PM
thanks everyone - super helpful! - off to the garage!! - get this together and back on the road!
Old 08-02-2024, 02:27 PM
just wanted to say thanks again for the help really appreciate it - bugger of a job - stainless nuts and bolt worked great as per the recommendations - all back together- time plus $5 in parts
Old 08-07-2024, 04:39 PM
