Headliner Padding - keep or replace?
Seeking advice —
Replacing my headliner and want to know the recommended course of action for the foam padding attached to the underside of the roof skin. The existing foam material is not sagging (yet).
1. Do I remove the existing foam padding or leave in place?
2. If replacing, what type of material is suggested?
76 911S Signature Edition w/ 3.2
Old 03-12-2025, 02:24 PM
PCA Member since 1988
The original foam padding is extremely durable. It doesn't fall apart after a dozen years like so much of the stuff available now. It's been in there for almost 50 years! I can also attest that getting off the original adhesive is a real PITA. Unless it's deteriorating, I would leave it alone.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-13-2025, 12:36 AM
digitaldgp's Avatar
When I had my Headliner redone, I had them use sound proofing material.
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 03-13-2025, 04:48 PM
