proporsche's Avatar
what NOT to use on rebuilding engine
Well,this becoming common thing here in Bohemia.Once a while i get to do engine which was in the hands of a mechanic with no clue or i`d say wants to be secure of oil leaks.
Cleaning this stuff off is not fun ..never mind all that crap inside the engine.
So do not use silicon stuff on these engine ,only recommended adhesives ...and only a little of it.
here are some samples i had to deal with and now dealing with another engine now.
1st is 993
2nd that Bohemian Singer i just worked on ..it is coming back for oil leaks and new oil return tubes
Notice the cylinder heads and through bolts
3rd
too much stuff on chain housing covers...
the last pic is the best , if you can find under the silicone the part;-)??
1985 911 with original 502 191 miles...808 198 km
Old 08-12-2024, 02:39 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Clearly done by people who have a little (dangerous) knowledge and run with it. Wait till they plug an oil orifice with all that excess floating around, then the real trouble begins.
1986 Targa Guards Red
2021 MT09 SP
Old 08-12-2024, 06:18 AM
proporsche's Avatar
that is one more reason i am doing this engine complete...as the others when i see this.
The last engine before 2 last one had the oil tubes for rockers totally plugged..
Ivan
Old 08-12-2024, 08:18 AM
PCA Member since 1988
Ugly.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-12-2024, 01:32 PM
AndrewCologne's Avatar
Ough .... Seems to be that Dirko red stuff.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 08-12-2024, 02:03 PM
proporsche's Avatar
It is actually something i would use on Chevy Monte Carlo back in the USA for valve cover gasket;-)back in the 1980`s...
The grey Dirko can be used but without the paper gaskets
Ivan
Old 08-12-2024, 02:09 PM
Exactly what this car on BAT looked like too:
https://bringatrailer.com/listing/1970-porsche-911s-coupe-28/
Pic 97:
Old 08-13-2024, 07:24 AM
theiceman's Avatar
i always "paint" my paper gaskets with a thin film of loctite 574 and have never had any issues.. But i had a friend show me a dish full of silicon he pulled out of an engine he was rebuilding due to oil starvation.. and we all know why.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 08-13-2024, 07:48 AM
574 is magic stuff. After my shift rod gasket started leaking i just pressed out a bit of the leak and it stopped. Great stuff and especially for valve covers.
Gone!
Old 08-13-2024, 03:20 PM
proporsche's Avatar
Oh ya one more thing -not adhesive related .If you work on your engine and drop something inside make sure you get it out not just replace it.Like this engine -that schmuck who did the cam.cover gaskets dropped the gear pin in and just replaced it with new.. and this is what happened.....
Old 08-14-2024, 08:41 AM
proporsche's Avatar
i got a little buzy here..but this repair beats them all..what an idiots..and they gave it to the client this car back with major oil leaks and said sorry.....It will be a challenge to fix this--have to take the engine apart ......so, do not never ever use too much force on this through oil bolt for the right camshaft.
Got that sucker out ...
Old 03-20-2025, 04:26 AM
See kids that’s why you don’t take LSD and work on customers engines. Can’t believe the guy who did that actually has a shop and clients.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 03-20-2025, 05:52 AM
proporsche's Avatar
yup ,long time Porsche repairs in these lands..i have done so many screw ups after him and another specialist who likes the red silicone;-)))He has big overhead-me,just a hobby;-)
Ivan
Old 03-20-2025, 07:12 AM
Perpetual Reassembler
2jmotorsports's Avatar
Does that Singer have a Cosworth, Ed Pink, or Porsche Motorsport engine?
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 03-20-2025, 08:17 AM
Counterclockwise?
Shows you that you cannot trust the details on BAT.
Rod
1986 Carrera
2001 996TT
Old 03-20-2025, 09:21 AM
proporsche's Avatar
hi there
oh no, none of the above.it is 1982 911Sc i just made it for the owner to run like street rocket after several so called 911 mechanics failed to find the problem with it for many years..The owner did, i must say very very nice job on the body-so i call it Bohemian Singer...
https://www.youtube.com/watch?v=46hRqXZCadc
Old 03-20-2025, 10:50 AM
proporsche's Avatar
possibly true...we do not have it here in Bohemia..but i did get to work on a 911 from Beverly Hills Cars Club..nightmare for sure...when it arrived in Europe
Ivan
Old 03-20-2025, 10:53 AM
Alan L's Avatar
My 930 was like that when I got it from Japan. Several colours of silicone. AND a timing pin in the crankcase. Luckily no damage. Found it in time.
And the sellers report stated 'freshly rebuilt engine'.
It was all downhill from there for the next year. Hard to believe these people are out there. I guess they must offer cheap rates?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-20-2025, 11:12 AM
Absolutely shocking!
Good luck with it.
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 03-20-2025, 11:50 AM
