Dansk or Bischoff muffler
I see there a few used mufflers available on various sites. Which is a better choice, if there is a better choice.
also i considered buy a full new muffler system minus the Catalytic converter. thoughts?
Old 08-14-2024, 01:29 PM
Uncertifiable!!!
Uwon's Avatar
Engine specs? Intended use? Noise level acceptability?
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 08-15-2024, 04:40 AM
3.2, driven for pleasure, not looking for hot rod sounds.. typical 911 sound level
Old 08-15-2024, 12:03 PM
Uncertifiable!!!
Uwon's Avatar
Try this one for $20
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1165692-bischoff-2-2-out-muffler-20-pickup-socal.html
Old 08-16-2024, 06:57 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
From experience on my '87 3.2:
- While I like my Dansk 1-in-2-out (84mm outlets) I find myself switching back to the stock-style muffler for longer highway trips as this particular Dansk is loud enough to be tiring for extended periods at highway speeds.
- The best thing I did to the exhaust system for both sound and performance is eliminate the cat and install a euro-style premuffler. I highly recommend the Fabspeed premuffler. (Please note that cat elimination pipes and premufflers are two different things.)
- For a 3.2 by far the best simple upgrade is a Steve Wong chip. That seems to really help the engine take advantage of the modified exhaust system. It only marginally improves peak HP, but it really helps in mid range RPM.
Old 08-16-2024, 07:08 PM
skinnerd's Avatar
Have to agree.
A single outlet stainless steel stock style muffler will be music to your ears in the long run.
Dansk makes these as do others.
Don't over think it and you'll be miles ahead.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 08-16-2024, 08:10 PM
PCA Member since 1988
For street use, especially daily or distance driving, Stick to the stock muff or equivalent replacement. The claims of power gains for different exhausts on street 3.2 engines are usually exaggerated. You will get more torque you can feel out of a Steve Wong chip.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-16-2024, 09:56 PM
yes, i would only install stock components. always have
Dansk is a good muffler.. that stock?
Old 08-21-2024, 04:18 PM
I'm not as familiar with Carrera exhausts as SC and earlier, so maybe someone else can answer. But Dansk makes several different types, and you want the one that is the stock replacement.
Old 08-21-2024, 11:12 PM
Tags
catalytic converter , exhaust , muffler
