Possible WUR issues with new to me 911
I have a 79 911 that I am having issues with the car as it warms. It starts fine and idles at approx. 1100 RPM, which drops to 900 or so within a few minutes. The car then starts to search for RPM after driving a short while and coming to a stop. Sometimes it will stubbled to the point of stalling. Once the cars is completely warmed the RPM search gradually diminishes. Here are my fuel pressure numbers. I ran the test with the WUR vacuum hose disconnected.
System pressure : 4.8 B @ 31c Cold Control Pressure 1.6B I ran a 10 minutes test with the WUR Connected 1M 2.2B 2M 2.4B 3M 2.5B The pressure does not increase after 4M Residual Pressure @0= 2.9 @15M =1.6 @30M = 1.35 Any advice is appreciated! Last edited by Jaymanbikes12; 08-21-2024 at 07:36 PM.. |
If you post your WUR number - stamped on the WUR, the specs will be known.
But it may abe a simple idle mix adjustment. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
PCA Member since 1988
Your SP is good and your RP measurements are good. Your cold CP is probably within spec, but the chart depends on the temp when you ran the test. At 20C, the graph shows 1.6-2.0 bar. Your warm CP is too low, should be 2.7-3.1 with vacuum disconnected.
HOWEVR, I don't think the WUR is causing the idle to "hunt" during warmup. IME, timing is an important influence, so make sure your timing is set correctly and increases to 25 or a bit more at full advance. Too much timing at idle tends to increase hunting. Are the vacuum hoses connected correctly? Have you oiled or disassembled and cleaned the dizzy yet? Does the vacuum advance can have two vacuum hose ports, one for advance and one for retard? Also see the parallel thread about "Higher rev when at stoplight or stop."
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 08-22-2024 at 03:22 PM.. |
My order for drivability would be 1) check for and fix vacuum leaks, 2) confirm fuel pressures are in line with the WUR specs, 3) confirm timing, 4) adjust fuel ratio and 5) adjust idle.
Agree with Ltanderso ...
First and foremost introduce yourself with good literature and the right videos onto CIS on 911 cars: 1. https://p914-6info.net/PDFs/K%20Jetronic%20Workshop%20Manual.pdf (access with Firefox e.g) 2. https://files.bmwclassic.nl/E21/K-Jet/Bosch_K-Jetronic_web.pdf In 1. you'll find also the WUR curve foryour car and all other relevant settings incl. procedures on how to make adjustments and repairs... Also I recommend the Porsche 911 Workshop Manual to study: https://www.turbosition.com/_files/documents/Porsche_911_Workshop_Manual_1972-1981_EN.pdf Also I always recommend Curts fabulous YT channel "KlassikATS" with it's video series about the 2.7 CIS 911 (there are a lot more videos about 911 there). Here you find almost everything you need to know about CIS. It's the perfect addition to the literature which is also still needed for details: https://www.youtube.com/playlist?list=PLkWFofpgz2OgF9FdliKnlzuY0pygqRkMj Also his website klassikats.com. So you're busy until X-mas ![]() Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
CIS Troubleshooting……….
Jay, Follow the above suggestions. One of the best recommendations I’ve seen recently for CIS troubleshooting. And have the following tools available
The control fuel pressures of your WUR-089 is out of spec and needs some calibration work. Confirm the absence of unmetered air going into the system before attempting to adjust your fuel mixture. This is the last thing you want to tinker if your motor is starting and running. Otherwise, you will be making a bad situation worse. Keep us posted. Tony |
Still here
WUR 0438140089 chart in this post ...
https://forums.pelicanparts.com/porsche-911-technical-forum/758788-cis-troubleshooting-dummies-5.html#post9693566 |
