Installing SSIs on my 1977 2.7
Hi,
I am planning on installing SSIs on my 1977 911 S Targa with a 2.7.
I am planning on using copious amounts of PB Blaster to loosen the nuts and then an induction heating element to break the rust.
I am planning on replacing the nuts with copper to make it easier, when I do my rebuild in the future.
I am going to buy the barrel nuts but was hoping for clarification on the non-barrel flanged nuts. Are they 12mm x 6 or 13mm x 6?
Any tips on replacing the exhaust gaskets, should I use the fiber/cloth with metal or solid metal instead?
Thanks,
Kevin
Old 08-26-2024, 04:05 PM
The nuts need to be heated cherry red
I believe the studs are 8mm
The factory used gaskets that are a metal fiber sandwich
Old 08-26-2024, 04:23 PM
The thick 84-89 carrera gaskets are the best IMHO.
206 637 4071
Old 08-26-2024, 04:45 PM
