Part # or specs help
Looking for part # or specs, please. Anyone can help with part #? I could not find on our host products search, scrolled thru 20+ pages.
Or, if you know the specs -- material, thickness, ID & OD, perhaps I can buy one @ HD? The washer that goes on the rolling pin holding the brake pedal and MC/Booster linkage together. See below --- I nicked a few fotos from Jose Martinez via his Blog to illustrate the part I'm looking for. While trying to reassemble the linkage, the washer fell under the pedal cluster --- I don't want to remove it. I'd rather just buy a new one. Thanks!!!! ![]()
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil |
Porsche part no. 900 031 005 02
Washer 10,5mm diameter (hole) Standard part, zinced steel, nothing special. The bolt is 10mm thick. For such investigations the Porsche PET parts catalogue is the source: https://www.porsche.com/international/accessoriesandservice/classic/originalpartscatalogue/ Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 08-30-2024 at 05:16 PM.. |
Thank you for your prompt response, Thomas! Appreciate you sharing the part #, dims, and the PET link.
I made a trip to HD. There weren't many choices for metric washers. So, went w a 3/8" washer. Re-assembled the linkage, and also got the accel pedal back into the ball rod. A bit of liquid soap, locking plier to hold the rod steady, and tap on the pedal face w mallet did the trick. Start early tomorrow AM to bleed the brakes w new MC. Quote:
