Odd Noise from Fan/Alternator
Hi Guys,
I noticed an odd noise when I turned off my '87 Carrera today after a quick drive around town. I was able to isolate the noise to the fan housing, and wound up catching it on video. Something remains spinning inside the housing after the ignition is turned off. In these videos you'll hear me say "off" to my wife who turns the key while I film. You'll see the part spinning (for a couple seconds) if you look through the holes just above the pulley belt. As you can see it appears to have a gear shape with teeth that's spinning, I'm at a loss as to what it could be. Amy help greatly appreciated, thanks so much! https://photos.app.goo.gl/Xi5Y4HfSUa2UGVK39 https://photos.app.goo.gl/asENma9svuVWyHyN6
____ 1987 Carrera 3.2L RoW Spec |
Here's a screenshot from one of the video's above, the red arrow points at the part that's spinning after ignition is turned off:
whoever put the alternator in most likely forgot or dropped some nut or washer in. It will stay in since it is magnetic.Take it a part and remove it..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
