SFR SFR is online now
Classic retrofit fuse box (mini fuses)
I just bought one of these from Audette and I don’t think it’s working properly.
Bottom line, the LEDs never light up.
It there a re-set or something that needs to be done to get them to work.
I’ve seen videos where they light up when you turn on the directions or have blown fuses…I get none of that.
The panel is working as everything in the car works.
Help (I have emailed Audette for info, nothing yet).
Old 09-06-2024, 06:07 PM
Slow old car
There is a switch on the fuse panel that you need to move to turn it to ‘test’ mode, I’m assuming you’ve found that though yeah?
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 09-06-2024, 08:32 PM
Mike - I have not seen the ‘test mode’ switch, where is it?
Old 09-06-2024, 08:52 PM
Kroon Wire Harnesses
I don't think the fuseboxes John is selling are the Classic Retrofit ones ?
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 09-06-2024, 10:32 PM
famoroso's Avatar
If it is, in fact, a Classic Retrofit panel, aren't the LEDs fuse *failure* indicators?
If you pull a fuse (emulating a blown fuse / opening the circuit), does the corresponding LED light up?
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 09-07-2024, 02:08 PM
Yup, red LED above the fuse. Only lights up when the fuse is blown/removed AND you're trying to operate the circuit.
The Audette fuse box has a two-color (red/green) LED below the fuse.
Red LED for fuse blown, Green LED for output live, Green LED when fuse removed, and backfeed is present.
Another way to tell is that the two relays are one above the other on the CR fuse box - looks to be two relays side-by-side on the Audette.
Classic Retrofit:
Audette:
'77 S with '78 930 power and a few other things.
Old 09-07-2024, 04:21 PM
Slow old car
In the pic right above, see the bottom left corner, that little red piece next to the bottom post for the left-most fuse is a switch that turns on test mode
Mike
Old 09-07-2024, 06:35 PM
Mike - that’s it, now it works.
Thank you.
Old 09-08-2024, 06:09 AM
SFR, you were happy with the installation ? tight fit for multiple cables or everything went smoothly ?
Old 09-10-2024, 01:55 AM
I was happy with the install; yea some of the wires were tight, but overall it was fine.
Old 09-10-2024, 11:38 AM
