fallingat120mph's Avatar
Engine removal/transmision seperation - 3.2l question...
Will be dropping a 3.2 from one of my 911's this week and will be removing both engine and transmission together.
At that point any advice on separating the tranny from the engine?
I was reading my manuals, looking at old threads, but couldn't find anything specific on the 3.2 with 915. Sorry if I missed a thread...
Since dropping both I don't think there is any big issues it seems the problems arise when people leave the transmission in the car (older models at least).
I'll remove the starter for sure and then it looks like three bolts.
Seems almost "too" easy...I say nervously.
Thanks for any updated insight. My search really turned up older cars, etc...
Erik
1986 911 Coupe
1986 911 Targa
Old 10-01-2024, 10:57 AM
Just remove the clutch release levers while it's still in the car and you're good.
206 637 4071
Old 10-01-2024, 12:23 PM
Thank you sir, much appreciated.
Erik
1986 911 Coupe
1986 911 Targa
Old 10-01-2024, 01:27 PM
As John mentioned above, you need to remove the clutch release levers while the engine is still in the car. This was difficult on my car, I sent through a few different types of pullers before I got them off. I think I needed snap ring pliers as well.
Starter can come off after you get the engine out.
I pulled the engine and transmission on my 84 Targa earlier this year. I sent the transmission out to CMS for a rebuild and I've been going through the cleaning, plating, powder coating, cerakote process on the engine.
I should have the car back together before the end of this year.
I put my engine removal process and checklist in this thread:
https://forums.pelicanparts.com/porsche-911-technical-forum/1153485-pulled-engine-my-84-targa-now-fun-begins.html
Old 10-02-2024, 10:07 AM
Here is my thread on pulling the levers:
https://forums.pelicanparts.com/porsche-911-technical-forum/1153356-can-t-get-clutch-arm-off-915-a.html
Old 10-02-2024, 10:50 AM
Great thread...no idea why that didn't appear on my searches. I was going to create a checklist myself, but seems you beat me to it.
Again, great thread and appreciate the response!
Erik
1986 911 Coupe
1986 911 Targa
Old 10-02-2024, 11:33 AM
kevbo's Avatar
Heidi and Fran video really helped me with first engine drop along with all the things to consider when doing what you're about to do.
https://www.youtube.com/watch?v=-2rvMKMqQ2k
Kevin
1986 Carrera Targa
Old 10-02-2024, 06:01 PM
Have about 5 open tabs open and one of them is their video (series) about dropping and separating. Plus it's a 3.2 also if I am not mistaken.
Wall mounted a TV in the garage so will be doing a lot of play/pause I am sure
Good call and thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 10-02-2024, 06:29 PM
pgeorgeson's Avatar
My tip (not so much for the engine/ transmission separation, but for the whole process), take lots of pictures along the way of any connectors you undo, etc. Everything that seems quite obvious when you’re taking it apart does not necessarily seem quite so obvious when you are putting it back together.
Old 10-02-2024, 10:02 PM
Just do it ten times and you won't need any more pictures. It's all in your head.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-03-2024, 06:56 AM
Agree 100%. New laptop so I can transfer immediately from my camera and phone into the "engine removal" file.
I am hoping after 2-3 times...but 10 is probably the safer bet.
1986 911 Coupe
1986 911 Targa
Old 10-03-2024, 01:41 PM
Dropped the engine/trans last night and separated with no issue.
Thanks to everyone for the input. I can see why you want to remove parts mentioned above when everything is still in place. Very easy job...so to speak.
Erik
1986 911 Coupe
1986 911 Targa
Old 10-05-2024, 03:55 AM
