}{arlequin's Avatar
'73 front and rear turn signal seals
I am planning on replacing the brittle ones. Is the rubber glue absolutely necessary when installing new ones? Or will it be sufficient if they are seated properly and pressed tightly by the lens?
Thanks,
dave.
Old 06-29-2003, 01:47 PM
nostatic's Avatar
I don't know about the '73, but on my '79 the rears do not require any goo, as the seal has a channel. It does take patience though...
Old 06-29-2003, 04:00 PM
The '73 won't need any adhesive. I just replaced one of mine and the old one was not glued, but Nostatic is definately right about the patience part.
Brian
'73 Carrera RS
'71 911S coupe 'Patrick'
'16 Cayman GT4
'91 C4 coupe
Old 06-29-2003, 04:54 PM
}{arlequin's Avatar
Thank you.
dave
1973,5
Old 06-29-2003, 09:01 PM
Early_S_Man's Avatar
The black 3M weatherstripping adhesive is the preferred method of retaining those seals. Factory seals were definitely glued in place! Rears are a bit easier ... but, I don't think the front '73 seals will ever fit properly unless glued.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-01-2003, 11:15 AM
