Jonny, thanks for the feedback. I'm aware of the need to correct bump steer. I currently have the spacer kit on my car. I know that's not enough for a 19mm raised spindle.
With the added suspension travel (and a decent bump steer curve) you could soften the front of your car up to 19's, and leaving the 26's in rear would be a great match. I just had to dig up this old post regarding the ride frequencies and the learning curve I went through with the Project: Quote:
here''s a summary of street oriented effects from t-bars on a 2650# Carrera w/ stock 20/18 underbody sways>> track, sways and shock pressures all affect this, your effect will be reflected in that
http://forums.pelicanparts.com/uploa...1732231452.jpg http://forums.pelicanparts.com/uploa...1732231452.jpg http://forums.pelicanparts.com/uploa...1732231452.jpg |
So the data above is a min. Tell me why it can't be considered as a spring rate |
The only increase in the force exerted by gas pressure through the shock stroke is due to the additional volume the shock shaft is taking up as the shock travels in bump, and it's very small as a proportion of the overall volume. If I had to guess it's a few pounds increase, if that. That 42 pounds can simply be considered as preload that the torsion bar doesn't have to deal with and it's not a dynamic component. |
And, even though I'm the last person that should be checking anyone's math, there seems to be something broken in the total/sprung/unsprung section that might be throwing off the frequencies as well.
Yes, the shocks also affect the suspension frequency. It's a "mass-spring-damper" equation, and because the shock damping increases as V^2, it's a non-linear frequency response. Same math as the RCL equations in electrical engineering.
PV = nrT again I don't know what the slope is, just that it is constant |
in the charts I did figure a nominal damping rate but it isn't used for anything, I was just curious how it compares to the published damping curves for the various varieties of Bilstein |
I'm not saying shocks don't affect the suspension, we're just talking about the simple calculation of how "stiff" either end of the car is. Like a weight bobbing on a spring, heavy weight on a soft spring bobs slowly, light weight on a stiff spring bobs quickly. Damping is not figured in this calculation - it's something you add to manage the resulting characteristics after the fact. This simple calculation results in a Hz value which is then commonly thrown around like Bill has at the bottom of his spreadsheet. I'm not making this up. First hit on google: http://forums.pelicanparts.com/uploa...1732372574.jpg |
PS - I'll try to ignore the insulting and irrelevant dissertation on how linear doesn't mean doubling.... to double the compression on a linear spring the force needs to double. Can you please make an effort to understand what I'm saying instead of going straight to insulting my intelligence? |
the compressed force can be measured but I didn't and don't have that information from any other source canister pressure which is the source of the shock force is a tuning tool for shocks like MCS and JRZ I use it because its there and the 42# is a minimum #, none of these #s are what one could call precise, there are all sorts of additional factors like the tire spring rate, scrub rate and stiction forces at play |
the unsprung &sprung isn't used elsewhere only the track is used to calculate roll rates I did fudge the corner weights and used a theoretical 40/60 split instead of the actual measured #s from my car, the actual measured f/r ratio is 39.5/60.5 & 2594# |
yes the 42# at full extension is a preload. the preload increase w/ compression and is proportional to the internal gas pressure described by the rule PV - nrT if the gas chamber volume is halved the pressure and temperature go up, some of the energy goes into P inc and some goes into T inc, I don't know the ratio there. Internally there is a nitrogen gas chamber separated from an oil filled chamber, the gas volume is compressible but stays in the chamber, the volume, pressure and temperature of the gas in the chamber varies in proportion to the shock piston movement, the pressurized gas forces the relatively incompressible working fluid through various orifices to damp the motion and shape the damping curve. the #s in this diagram are notional not specific to a 911 http://forums.pelicanparts.com/uploa...1732387150.jpg the gas pressure pushes the chassis upward just like a spring, the min. value for this upward push is ~42# the max is unknown to me if it walks like a duck and quacks like a duck treat it like a duck http://forums.pelicanparts.com/uploa...1732388437.jpg http://forums.pelicanparts.com/uploa...1732388437.jpg http://forums.pelicanparts.com/uploa...1732388437.jpg |
I tend to agree with Jonny about the pressure inside Bilstiens acting more like preload than additional spring constant. However the way to find out is to put a Bilstien on a scale and press down on it at the top of the stroke and the bottom of the stroke to find the spring constant. I don't have time to do that this weekend because I have a plumbing project to finish--house plumbing, that is, "honey do" list.
Jonny, the equation you found with Google is a first order approximation, good for comparing the suspensions when just changing the springs. As I said before, the damping contributes greatly to the suspension frequency response and "felt stiffness." You probably know that too. For others following with a casual interest, consider the difference in response for a shock with very little damping, versus a shock with a LOT of damping. In the first case, the suspension will bounce up and down a lot before ironing out, at pretty close to the sping/mass frequency Jonny cited above. But with a lot of damping, that movement will be slowed considerably--thus necessarily decreasing the suspension frequency--even though it makes the ride feel much stiffer. That brings up something I emphasize frequently: The harshness of the suspension that you feel in your butt depends more on the damping (shock stiffness) than the stiffness of the springs. You can prove this to yourself if you have adjustable shocks (like my Koni's) by setting the shocks at their softest and then comparing to the settings at their hardest. Big difference, with the same springs/T-bars. And, yes, shocks with digressive valves or other valve designs complicate these relationships further. I find that for a street car, I prefer moderately stiff springs/T-bars, with moderately soft shocks to tame rough roads and maintain a reasonably comfortable ride without too much roll or wallowing. Race cars are a different case. |
Just barely compressed: http://forums.pelicanparts.com/uploa...1732405901.jpg Almost fully compressed: http://forums.pelicanparts.com/uploa...1732405901.jpg So, the effective spring rate of the gas charge is less than 1lb/in. |
still its a 42# shock rate * .9 to get wheel rate added to the t-bar rate an 18.8mm front w/ wheel rate of ~110lb/in becomes ~148l b/in + ~4# at full compression for ~152#/in max |
Which is the whole point I'm trying to make, and the reason the ride frequencies you're coming up with are so high. Does it not strike you as odd that your calculated frequencies are double that of a typical passenger car? |
| All times are GMT -8. The time now is 03:12 AM. |
