-   -   KW V3 Spindle/Hub Installation Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/1169971-kw-v3-spindle-hub-installation-problem.html)
930DL 11-09-2024 08:10 AM
Hi Everyone,
I'm rebuilding the suspension on my 1980 911 Turbo. I bought a pair of KW V3 shocks and ran into a problem with the installation. I decided to use my old bearings (they look good) but when I go to put the hub on the spindle, it gets stuck. The hub/bearings will not go on all the way. I can get it to where it will just about go onto the inner spacer. When I go try on the old spindles, it fits no problem. Also when I get them partially installed on the new spindle, it is then very difficult to remove. This problem happens for both new spindles (right and left).
In the KW V3 Installation instructions it says "Pay attention to a clean and zinc-free surface of the axle journal. Remove the zinc coating with a fine sandpaper or abrasive fleece". Does this mean I need to sand down the spindle?
Has anyone had this problem or have any ideas.
H-viken 11-10-2024 12:30 AM
Yes, you need to very carefully remove the coating. I had to do it to mine as well. Why they have chosen to go down this path is beyond me. Seems like opening the door for amateurs like me to F it up
930DL 11-11-2024 05:48 AM
The official response from KW is...
"Only the area where the bearing ring will sit has to be sanded carefully until it’s zinc-free, otherwise it’s not possible to mount the ring. "
I installed the bearing ring (spacer that does most towards the rotor) and its o-ring no problem.
I'll write back and see what they say.
75 911s 11-11-2024 06:05 AM
Wow interesting. Perhaps it is to obtain a really close bearing tolerance? Or to protect the surface while shipping?
shoooo32 11-11-2024 08:15 AM
Why wouldn't they compensate the journal size for coating buildup or mask it? Masking the spindles would add $10 max to the plating cost and save a ton of headache for the consumer.
Cory M 11-11-2024 08:24 AM
Wow Pretty ridiculous that a company like KW can't do the finishing steps themselves, or account for the additional thickness/mask so it isn't a problem. Doesn't seem smart to require amateurs to remove material from a sensitive area on your parts.
shoooo32 11-11-2024 10:17 AM
I'm glad I saw this - I have a set shipping to me right now. I'll measure them when they come in and calculate plating thickness.
930DL 11-12-2024 12:42 AM
KW sent me the following for measurements for the spindle. I'll take some measurements today.
http://forums.pelicanparts.com/uploa...1731400888.png
75 911s 11-12-2024 04:10 AM
Tony can you post a few pics of the coating too? Very curious what this looks like. Do you have bearing you could slide on also?
H-viken 11-12-2024 04:56 AM
I believe you also need to remove the coating where the outer, smaller bearing sits
shoooo32 11-12-2024 06:30 AM
I've got fresh bearings we can play with - will post photos when they dock sometime next week.
930DL 11-14-2024 07:55 AM
I bought some new bearings to see how they fit. Will update this weekend
930DL 11-16-2024 06:28 AM
*Update*
I tried to see how new bearings fit on the spindle and...... they don't. They get stuck right away. The spindle is just a little too big, so I am hoping just some sanding of the surface paint will allow them to slide on.
I'll be messaging KW about this and keep everyone updated on the response.
shoooo32 11-17-2024 06:48 AM
My set cleared customs in Chicago last week and were "out for delivery" before our friends at FedEx routed them to Memphis. They'll theoretically dock tomorrow.
shoooo32 11-19-2024 06:31 AM
The coating feels "plastic-like", which is good for the exposed portions but needs to be removed from the bearing surfaces. Best guess, there's about .05mm interference due to the coating. I didn't have 600 grit emery cloth handy and didn't want to use anything rougher. I'll measure again once the coating is removed.
http://forums.pelicanparts.com/uploa...1732026302.jpg
PeteKz 11-19-2024 01:25 PM
Following. I want to install struts with raised spindles and 3.5" caliper mounts in my 1973 car. Not too many late Carrera front struts available, so I'm considering just going with the KW struts to replace my current OE Boge 3" caliper struts with Koni Sport inserts. I want to know how this eventually turns out for you.
H-viken 11-20-2024 02:05 AM
Pete, I have them on my car and am happy. Just a tad annoyed having to manually remove a coating, which should have been done by KW before leaving the factory
PeteKz 11-20-2024 11:02 AM
What strut inserts did you have previously? Are the KW noticeably better, and how so?
Jonny042 11-20-2024 06:36 PM
It's a shame they switched to paint from their previous plating, they were just so gorgeous!!! But also explains why the need to remove the paint from the bearing area. Expect to have to do it for the inner spacer and outer bearing race.
Jonny042 11-20-2024 07:02 PM
I'll interject with my experience - they are noticeably awesome. Independent compression and rebound adjustment. By the looks of it the price went way up since I got them.
Depending on your wheel size people have had issue with 19mm raised spindles and 15" wheels, I had to great creative with a grinder to clear the 15x7 fuchs on the front of that car.
Also, you must, must, must correct bump steer when raising spindles. I ended up using 42mm of spacer to get it right. Getting rid of the bump steer made a huge difference in the handling of the car.
This thread will point you in the right direction:
https://forums.pelicanparts.com/porsche-911-technical-forum/1116600-19mm-raised-front-spindles-adjustable-bump-steer-no-4.html
