Ebrake install help for 930 rears on 911SC
Hi all!
I looking to work out what parts I need to reinstall a mechanical ebrake system on my 911SC that has 930 brakes installed. I believe all the ebrake parts have been removed as this was a racecar and gutted in a previous life. Are brake parts universal? I will get some pics shortly to work out what to do! Any other options other than factory ebrakes handle / actuator that are popular? Thanks in advance! |
http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/89933-e-brake-using-930-calipers.html
This kind of implies I need something custom…. Willwood mech calipers or some mod to factory stuff to make it work. My calipers are indeed on the forward side of the rotor. Maybe it would work on a 911 vs the thread is for 914? Unclear. |
http://forums.pelicanparts.com/uploa...1731331895.jpg http://forums.pelicanparts.com/uploa...1731331930.jpg PS: Or do you mean 930 non turbos (no 4-piston calipers)? |
Were your 930 brakes redrilled for 3" spacing to fit on the SC trailing arm? In that case I might try SC parts. I think they would work even with the different Turbo rotor but haven't done it personally.
Thanks all! Will post some pictures shortly today and get some definitive answers hopefully on what to order :)
Did this on my "83 SC a while back. All of the parking brake hardware was retained and works perfectly with the 930 rotor. You can see in pic # 3 and # 4 the parking brake backing plate with the rotor installed.
http://forums.pelicanparts.com/uploa...1731347644.jpg http://forums.pelicanparts.com/uploa...1731347644.jpg http://forums.pelicanparts.com/uploa...1731347644.jpg http://forums.pelicanparts.com/uploa...1731347644.jpg http://forums.pelicanparts.com/uploa...1731348209.jpg http://forums.pelicanparts.com/uploa...1731348209.jpg |
Pics
Pic of bolts . Hard to see or know what modification was done to mount?
Hard to measure but seems like 3 spacing? Maybe 3.1 by my paper impression but probably its 3
http://forums.pelicanparts.com/uploa...1731353698.jpg |
http://forums.pelicanparts.com/uploa...1731353698.jpg http://forums.pelicanparts.com/uploa...1731354454.jpg http://forums.pelicanparts.com/uploa...1731354454.jpg |
all 911 from at least 69 are 3" leading mount, stock the calipers need to be modified to fit the al. semi trailing arms or new inner halves w/ the proper 3" mounts purchased, part #911.352.540.00 http://forums.pelicanparts.com/uploa...1731357848.jpg http://forums.pelicanparts.com/uploa...1731357848.jpg http://forums.pelicanparts.com/uploa...1731357848.jpg stock 3.5" rear http://forums.pelicanparts.com/uploa...1731357848.jpg modified rear http://forums.pelicanparts.com/uploa...1731357848.jpg |
Hmm seems I have the new inner half as it looks like that part number
Ok so consensus seems to be I can get all the SC parking brake gear and it will work! I’ll let you all know how it goes!
| All times are GMT -8. The time now is 08:53 AM. |
