Ebrake install help for 930 rears on 911SC
Hi all!
I looking to work out what parts I need to reinstall a mechanical ebrake system on my 911SC that has 930 brakes installed.
I believe all the ebrake parts have been removed as this was a racecar and gutted in a previous life.
Are brake parts universal? I will get some pics shortly to work out what to do!
Any other options other than factory ebrakes handle / actuator that are popular?
Thanks in advance!
Old 11-10-2024, 03:40 PM
e-brake using 930 calipers
This kind of implies I need something custom….
Willwood mech calipers or some mod to factory stuff to make it work. My calipers are indeed on the forward side of the rotor.
Maybe it would work on a 911 vs the thread is for 914? Unclear.
Old 11-10-2024, 04:07 PM
Bill Verburg's Avatar
Originally Posted by Tap46 View Post
Hi all!
Thanks in advance!
SC and 930 e-brakes parts ae the same, just reinstall the SC or Carrera stuff.
Bill Verburg
Old 11-10-2024, 04:17 PM
proffighter's Avatar
No, the are not. Besides different shoes/springs (at least in PET) different mechanism:
PS: Or do you mean 930 non turbos (no 4-piston calipers)?
Roland
930 Turbo '81 Too many modifications to list
Old 11-11-2024, 05:32 AM
Registered Minimalist
75 911s's Avatar
Were your 930 brakes redrilled for 3" spacing to fit on the SC trailing arm? In that case I might try SC parts. I think they would work even with the different Turbo rotor but haven't done it personally.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-11-2024, 06:14 AM
I mean that the SC parking brake works fine w/ either 911 or 930 rotors, I've had mine for over 40 yrs.
Bill Verburg
Old 11-11-2024, 08:03 AM
yes the 930 calipers need to be modified to 3" leading mounts and the dust shield will need top be discarded, but the parking brakes are totally compatible.
Bill Verburg
Old 11-11-2024, 08:05 AM
Thanks all! Will post some pictures shortly today and get some definitive answers hopefully on what to order
Old 11-11-2024, 09:30 AM
stevie 77 930's Avatar
Did this on my "83 SC a while back. All of the parking brake hardware was retained and works perfectly with the 930 rotor. You can see in pic # 3 and # 4 the parking brake backing plate with the rotor installed.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 11-11-2024, 10:08 AM
Pics
Pics for more clarity
Old 11-11-2024, 11:13 AM
Pic of bolts . Hard to see or know what modification was done to mount?
Hard to measure but seems like 3” spacing? Maybe 3.1” by my paper impression but probably it’s 3”
Old 11-11-2024, 11:35 AM
Old 11-11-2024, 11:49 AM
from '78 930 rear calipers are 3.5" trailing mount, stock
all 911 from at least 69 are 3" leading mount, stock
the calipers need to be modified to fit the al. semi trailing arms
or new inner halves w/ the proper 3" mounts purchased, part #911.352.540.00
stock 3.5" rear
modified rear
Bill Verburg
Old 11-11-2024, 12:54 PM
Hmm seems I have the new inner half as it looks like that part number
Old 11-11-2024, 10:15 PM
Ok so consensus seems to be I can get all the SC parking brake gear and it will work! I’ll let you all know how it goes!
Old 11-12-2024, 01:22 AM
